u-boot serial port speed?
I recently got a RockPro64 and I'm assuming it's using u-boot. I have a USB serial port adapter attached to my board and I can log in at 115200.
However, when I power cycle the board I see that it's outputting something with different serial port parameters. What are the serial port settings to be able to interact with u-boot? And what is the command sequence to get into the u-boot command line?
Thanks!
(10-06-2018, 08:26 AM)zener Wrote: I recently got a RockPro64 and I'm assuming it's using u-boot. I have a USB serial port adapter attached to my board and I can log in at 115200.
Thanks!
  • Baudrate: 1500000
  • Data bits: 8
  • Parity: N
  • Stop bits: 1
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Wow, I tried 115200 and down to 9600. 1500000 works great. Thanks!
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 392 06-21-2025, 06:21 AM
Last Post: aleksei
  Serial Output Garbage after initial messages jamforlunch 5 5,121 09-07-2024, 03:32 PM
Last Post: foresto
  enble boot after power loss/restore dkebler 18 16,379 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 163,971 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 1,570 09-08-2023, 08:14 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 1,368 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 6,755 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 7,301 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 2,384 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 12,578 09-05-2022, 04:23 PM
Last Post: ljones
