Android 8.1 Released
(09-27-2018, 08:32 PM)Griffi30 Wrote: RemixOS didn't boot. Linux wont work on my SD card for some reason.
Back to the pink screen with no apps, SD card Android.
It plays some movies via the USB but still no way to run Google Apps.
Sideload from APK Mirror is the only hope and figuring out some apps that "work" is a pain.
So it will sit crunching Boinc in the corner while I play with my Tinkerboard and Rpies.
I ordered 5 Pine A64 boards for a Cluster build. Maybe the older boards will play well.
I'm a beta tester.
Remix OS ? There is no Remix OS for the RPro64... Are you sure you're flashing the correct images ?
I'm a beta tester.
I downloaded the Rock64 image and tried it. Would not boot. I didn't expect it to work but worth a try.
Linux wont either. Not sure what is wrong there the Etcher says error, I will try it again tomorrow.
SD Card is Samsung 32Gb EVO.
Might try Debian. I know it's not Pine's fault and they are not responsible for OS releases but hey, Im trying and it never hurts to try.
So Next is Debian. Anyone else have an OS they want me to try?
I saw the Android 8.1 image there in software release wiki. But the SDK portion just is 7.1 there.
May I know about where or when to get the Android 8.x version SDK??
Thanks a lot.
Sincerely.
Jack Chen.
(09-27-2018, 04:29 PM)ameridroid Wrote: Hello Pine Team,
Will this available for MicroSD boot later down the road?
I would rather use eMMC but I have some customers asking about using MicroSD for 8.1 for RP64.
Thank you
Stephen
Same.
Don't have an eMMC but have an SD.
Thank you
Stephen
Same.
The Android 8.1 SD boot build hopefully can released on this week.
(09-28-2018, 08:54 PM)Griffi30 Wrote: I downloaded the Rock64 image and tried it. Would not boot. I didn't expect it to work but worth a try.
Hey, just in case you bumped into the same issue as me. It takes a long time for the first boot and there's absolutely no indication of progress. But after waiting maybe a hour (maybe less, I just left the board to run) the board boots. I've used a 16GB SD card, it could be that 32GB card takes twice as much.
I've used this image: http://files.pine64.org/os/ROCKPro64/and...oot.img.gz (md5 CE39642A379B357BB3E4BC80ACA2E0CE) and just dd'ed it to the card without any extra tools.
  Android images for RockPro64 BitAnnihilator 1 116 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,814 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,651 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,059 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,499 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,211 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,723 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 25,018 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,134 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 4,050 04-16-2021, 02:03 AM
Last Post: Wizzard
