Lego Case
I plan on building a Lego NES case when I finally get mine. Will probably need to run to the lego store at some point to get the pieces I need, but would anyone happen to know the parts list to make something like this?
(01-30-2016, 11:59 PM)Kiryu Wrote: I plan on building a Lego NES case when I finally get mine. Will probably need to run to the lego store at some point to get the pieces I need, but would anyone happen to know the parts list to make something like this?
Well, there's this one:
http://legogenre.com/first-game-console-...tructions/
Parts list and instructions .pdf are down towards the bottom of the article Smile
Just a suggestion, if anyone has done a superb casing made for the Pine out of LEGO, can you guys share it here?
Also what would be helpful would be to leave the list of parts used to build the casing. Hopefully it can give people some ideas on building one themselves (like me Big Grin).
Thank you very much Smile
(02-19-2016, 04:36 AM)leongzhi Wrote: Just a suggestion, if anyone has done a superb casing made for the Pine out of LEGO, can you guys share it here?
We have make one and you can spot at KS video. If you have enough Lego piece, just takes less than 30 mins to build on. Some place you may need to use the "half height" Lego pieces.
Played around while the kids was building with Lego. Here is the result....
(03-31-2016, 08:13 AM)Tarjei85 Wrote: Played around while the kids was building with Lego. Here is the result....
Beautiful, can you take a picture of all the sides? That would be really helpful..
Will do when I get home.
EDIT: Finaly got home... here is the pictures...
Thanks a bunch mate!
Love it... Smile
Brick
This is a case i build with the pieces i had available.
You can find the building plans here: https://drive.google.com/folderview?id=0...sp=sharing
Latter I'll post instructions on how to add a power button. Takes 3 pieces of lego technic and its done.
Pine 64 2GB - Remix OS  - HP wireless keyboard = Working - PS3 controller with USB = Working
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,700 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,992 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,425 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,631 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,106 07-18-2017, 10:39 AM
  A case with active cooling for 1Gb pine64 ishwest 5 10,129 06-28-2017, 04:05 AM
Last Post: ishwest
  Acrylic case with Lipo Holder and 2 Tactile push button included killor 9 13,166 10-24-2016, 08:18 AM
Last Post: killor
  Pine64 Layer case modmypi 2 5,341 10-04-2016, 02:45 AM
Last Post: modmypi
Photo Weatherproof case build ltorsini 10 29,545 10-02-2016, 10:49 PM
Last Post: ltorsini
  Playbox case orderable? schindlb 8 13,725 10-02-2016, 08:20 AM
Last Post: schindlb
