PineTab2 corrupted EMMC
Today i got my PineTab2 delivered. Unfortunately it seems, that the emmc is somehow corrupted.
The Tablet won't turn on.
I created MicroSD Card with factory Image from here:
https://echo.danctnix.org:7269/danctnix-...527.img.xz
When i turn it on with the Debug Adapter booting from Micro-SD Card it boots from MicroSD Card.
When i choose Flash OS to emmc card, it begins to write, but it throws some errors, about mmc init (See log)
When the writing is about 60% it shows - Flashing Successfull. When i switch off the tablet, but it still wont turn on.
(11-16-2023, 06:01 PM)explit Wrote: Today i got my PineTab2 delivered. Unfortunately it seems, that the emmc is somehow corrupted.
Looks like Flash process premature quite at 60% and fro sure the code in eMMC still not complete programmed. Please reflash again and hopefully this time 100% completed.
After 26 unsuccessful attempts to reflash the emmc - it worked.
I don't know what changed, battery was charged over 80%.
Suddenly there were no more mmc initialization errors and the process could go over 100% successfully. Thread can be closed. Thanks all for support and help!
How did you get to the PineTab2 Factory Tool?  I'm looking to re-install Arch on my PineTab 2 using the UART adapter, but it just boots to login screen.  I'm not sure how to get to this factory tool.  Thanks!
Disregard.  Big Grin
My reflashing of the emmc only took ~8 attempts. Failing progress was to slowly get to 60% and then ended with no error. Not sure what I did differently but power was plugged into UART board and battery was at 100% at time of successful re-flashing.
Video Pinetab2 camera drivers cringeops 9 1,339 03-18-2024, 11:40 AM
Last Post: cringeops
  eMMC backup - pinetab2 pinetar.gz 0 542 01-07-2024, 09:08 PM
Last Post: pinetar.gz
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 2,999 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Touch doesnt rotate on Sway in PineTab2 cgbarros 4 2,243 08-03-2023, 05:49 PM
Last Post: cgbarros
  Disabling PineTab2 physical keyboard and touchpad? johns 7 2,050 08-03-2023, 11:55 AM
Last Post: cgbarros
  Will sudo pacman -Syu brick the PineTab2? cgbarros 10 3,043 07-24-2023, 01:15 PM
Last Post: rqkeating
  Udemy not working on pinetab2 (danctnix) jbreese 3 1,246 06-13-2023, 11:34 AM
Last Post: jbreese
  Factory reset / load to eMMC brentashley 7 12,688 09-16-2020, 07:16 PM
Last Post: brentashley
