Newbie Question!!
Can i install manjaro phosh on pinebook pro?  if yes is it working fine without issues?
Phosh is a phone UI, it's not meant for notebooks and will not work properly without a touchscreen.
(10-20-2023, 07:11 AM)oniichann Wrote: Can i install manjaro phosh on pinebook pro?  if yes is it working fine without issues?
Yes, you can. Images are found under https://github.com/manjaro-arm/pinetab2-...g/20231016 . You can copy an image to an SD-card (e.g. with a "dd" command), and launch it. I managed to use Wifi via an USB-dongle (there is a related post in this forum), and phosh runs. Of course in a quite immature state...
(10-26-2023, 05:03 AM)stefan_hdb Wrote: https://github.com/manjaro-arm/pinetab2-...g/20231016
you've directed OP to a repo for Manjaro PineTab 2 imgs, those won't work on the PBP.
While, OP, you can run Phosh on a PBP, you'll likely need to move into a TTY, login, and then have pamac install/uninstall the necessary packages and their conflicts. As mentioned above, b/c Phosh is meant as a handheld UI, it's not going to as pleasant to use on the PBP.
  Newbie with immediate issue jasonumd 1 1,011 03-04-2023, 05:59 PM
Last Post: hacknix
  GPIO breakout question pinus_pinea 0 690 01-17-2023, 06:13 AM
Last Post: pinus_pinea
  Wont charge when powered off, and update question pineymousepad 7 6,075 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Network connection question??? davehetfield 1 3,990 03-11-2021, 07:31 AM
Last Post: tkudog
  Novice question: Pinebook Pro does boot (does it?) but black screen Gert V. 21 19,855 01-27-2021, 10:48 PM
Last Post: rimaille
Brick Battery / power question GloriousCoffee 3 4,424 02-13-2020, 10:02 AM
Last Post: rleasle
  Hardware video decoding question sgx2 1 2,784 01-15-2020, 01:48 PM
Last Post: RotatingNut
  Silly question: Stadia on PBP? fpex73 0 1,884 01-11-2020, 08:08 AM
Last Post: fpex73
  Help for a clueless newbie? breezy 3 4,751 01-06-2020, 07:07 AM
  Newbie's first experience chrispop99 2 3,029 01-01-2020, 03:15 PM
Last Post: chrispop99
