Mobian .desktop file creation
I'm trying to write a temporary installer for a program I'm working on, and none of the .desktop files I have created have shown up on Phosh on Mobian
I've tried:
~/.local/share/applications/
and
/home/mobian/.local/share/applications
as locations for the .desktop files, and it *still* doesn't show up..
I've made desktop files before on Manjaro Phosh, and didn't have any of these struggles, any help would be appreciated, i've been working on this for hooooooours @_@
Since those paths looks okay could you paste what is inside your .desktop file Smile?
#!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Exec=/home/mobian/MyWaydroidManager/MyWaydroidManager.py
X-Purism-FormFactor=Workstation;Mobile;
Name=My Waydroid Manager
Comment=Manage Waydroid installations easily
Icon=/home/mobian/MyWaydroidManager/icons/icon.svg
Categories=utility
(07-20-2023, 01:14 PM)alaraajavamma Wrote: Since those paths looks okay could you paste what is inside your .desktop file Smile?
(07-20-2023, 03:05 PM)MadameMalady Wrote: #!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility
Remove the bin bash Smile
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility
I've tried that too and I didn't have luck Sad
Here's the whole option in the script, maybe i'm messing something up..?
if [ $(hostname) = 'mobian' ]; then
  notify-send "My Waydroid Manager" "Check Your Terminal"
  # copy application directory
  cd ..
  sudo mkdir -p /home/mobian/MyWaydroidManager
  sudo cp My_Waydroid_Manager.py /home/mobian/MyWaydroidManager
  sudo cp -r icons /home/mobian/MyWaydroidManager
  sudo cp -r scripts /home/mobian/MyWaydroidManager
  cd  ~/.local/share/applications/
  sudo touch MyWaydroidManager.desktop
  echo "#!/bin/bash
[Desktop Entry]
Type=Application
NoDisplay=false
Version=0.1.9
Type=Application
Terminal=true
Categories=utility">MyWaydroidManager.desktop
this option is in a directory called scripts, since the program is in 'scripts' when this option is ran, I have it cd .. back up a directory to start.
The #!/bin/bash definitely does not make sense, use #!/usr/bin/xdg-open or #!/usr/bin/env xdg-open or no #! at all.
(07-21-2023, 07:32 AM)Kevin Kofler Wrote: The #!/bin/bash definitely does not make sense, use #!/usr/bin/xdg-open or #!/usr/bin/env xdg-open or no #! at all.
Tried without any shebang at all (still no luck at all) , what's xdg-open do? / what/s xdg?
[Desktop Entry]
Version=0.1.9
Terminal=true
Type=Application
Try if this works. Also make sure that you have written the file name correctly like mywaydroidmanager.desktop
(07-21-2023, 10:22 AM)alaraajavamma Wrote:
[Desktop Entry]
Version=0.1.9
Terminal=true
Type=Application
I ended up putting the X-purism line right after the icon like, but that worked, thanks!
now to figure out how to prevent it from making the buttons smaller bc it opened the terminal first.. ?
So, that does make the icon show up correctly, but it doesn't run any of the commands in the opened terminal bc it's read-only, is that related at all or a different issue?
xdg-open opens a document with the document opening tool provided by your desktop environment. (xdg stands for "Cross-Desktop Group".) This works for files such as word processor documents or spreadsheets, but also for .desktop files. So if you want to make the .desktop file executable as a script, that is the tool for it. But there is generally no need to make .desktop files directly executable at all.
  Debian vs Mobian henrythemouse 3 917 04-06-2025, 02:15 AM
Last Post: henrythemouse
  July 1 upgrade of Mobian Bookworm boot loops. mburns 9 3,466 02-25-2025, 08:27 AM
Rainbow Plasma-Mobile on Mobian Trixie, task switcher issue pineconeuser 0 544 01-02-2025, 09:21 AM
Last Post: pineconeuser
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 3 2,175 10-28-2024, 10:46 AM
Last Post: Jite
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 8,996 04-28-2024, 01:52 AM
Last Post: diederik
  Disable the GDM service in Mobian. mburns 0 1,032 11-25-2023, 10:19 PM
Last Post: mburns
  The Mobian Phosh Experience mburns 1 2,047 11-18-2023, 08:21 AM
Last Post: crocspot
  "failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 OhMeadhbh 1 1,540 11-09-2023, 07:39 AM
Last Post: mburns
  Fix the Mobian Weather App mburns 0 1,090 11-07-2023, 10:01 AM
Last Post: mburns
  Mobian Phosh Gnome Software Is Recommending A Broken Update. mburns 0 1,173 10-14-2023, 11:57 AM
Last Post: mburns
