Pinetab2 Battery indicator
Hello ! I received my pinetab a few days ago, after some testing  and installing some apps, the battery indicator
stays at 100 %. In settings shows discharging but is after an hour still at 100 %.
Would be great if someone has an idea how to solve this
does the 100% battery persist through logouts/reboots?
(06-15-2023, 07:22 AM)tophneal Wrote: does the 100% battery persist through logouts/reboots?
yes, no matter if I reboot, shutdown or even tried to create an new user, battery stays at 100 %
I can confirm this, the latest update seems to have broken the battery percentage display; it’s always showing 100%. (Before the update, it did show the correct values).
I shut it off last night showing 100%, didn’t charge it overnight & today my PT2 wouldn’t function at all.
I plugged in a charger and it automatically powered up, working as normal; used it all day at work with no change in battery status (with power applied or not). It only shows “Battery at 100%, Charging”.
Reminds me of my old Jeep CJ-5, where the fuel gauge was always stuck, had to knock on the tank to see what gas I had.
I haven’t modified the kernel or system yet (busy at work), only added the Blackarch repo and some tools, so I don't think my modifications caused the problem.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
Same here, and I haven't even added any other repos. I've only installed/updated through pacman & discover. The battery indicator always shows full, no matter how long I run the tablet.
I *did* see varying percentages the first day I ran it straight out of the box, and I'm not sure exactly when it got stuck, whether it was before or after the first major update I ran.
I was poking fun a bit there, that’s why I referenced my old Jeep. The battery indicator is borked, but this tablet has an outstanding battery life.
I still haven’t gone back to my PBP, as this little device has met all of daily needs; I’m looking forward to some days off where I can really get into it & actually start testing things.
Another data point: After draining the battery to 0, then plugging the tablet in and powering it on, the indicator *is* updating while it charges. I wonder if it'll get stuck during charging, when it hits 100, or if the problem will clear up.
Would this be the right place to open a Github issue for the indicator on PineTab 2?
https://github.com/dreemurrs-embedded/Pine64-Arch/
FWIW, the indicator has worked perfectly ever since, so I suspect it may have been fixed in one of the recent updates.
  New PineTab2 dRateNWAytORy 2 242 05-11-2024, 09:46 AM
Last Post: frtodd
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 269 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 456 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 912 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 788 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,509 09-25-2023, 08:29 PM
Last Post: bluemage
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,064 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,238 08-23-2023, 09:38 AM
Last Post: diederik
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,361 07-14-2023, 03:09 AM
Last Post: gregb49
  PineTab2 virtual keyboard: symbols instead of numbers clemfandango 5 2,155 07-12-2023, 05:32 AM
Last Post: mtomaschett
