Broken Camera ?
Question
Has my Pinebook Pro camera broken, or has some update messed with the camera? Running Cheese immediately gives the error shown in the attached screen shot.
Is your camera privacy switch switched on? Are you using the correct device? Does anything besides Cheese work? (I have always had disastrous results trying Cheese)
:wq
[ SRA accepts you ]
(11-28-2022, 05:39 PM)KC9UDX Wrote: Is your camera privacy switch switched on?  Are you using the correct device?  Does anything besides Cheese work?  (I have always had disastrous results trying Cheese)
The camera is turned on. Trying to change the setting changed the error to No Device. You are on to something about Cheese. It used to work fine, but doesn't appear to anymore. I went to zoom.us in Vivaldi and my camera/mic work fine there. Thanks KCUDX.
Anthony
  Broken Screen vxzero 0 1,371 08-26-2021, 09:02 PM
Last Post: vxzero
  Replacing the camera? lfourquaux 1 2,254 05-26-2021, 08:24 AM
  Pinebook Pro broken eDP connector Ocawesome101 4 6,555 01-16-2021, 11:42 PM
Last Post: dsimic
  Replacement for video cable (EDP to LCD/camera)? pnwkayaker 2 4,042 10-13-2020, 08:42 PM
Last Post: pnwkayaker
  Pinebook Pro Broken Hinge uncmonky 1 3,213 08-02-2020, 01:43 PM
Last Post: Arwen
  Plastic around camera loose, easy fix? poVoq 0 1,861 08-02-2020, 01:34 PM
Last Post: poVoq
  Screws broken off / General comment on inner Life of PB stefan.schumacher 5 5,856 07-13-2020, 04:58 PM
Last Post: bcnaz
  Broken Spacebar on PBP ISO Jeremiah Cornelius 4 5,069 01-29-2020, 10:15 PM
Last Post: Jeremiah Cornelius
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 10,943 12-19-2019, 05:15 AM
Last Post: ndp
