Case for Pinephone
(08-07-2022, 05:53 AM)kuleszdl Wrote: Hi folks,
I bought two cases of phones with "similar" shapes, namely the Galaxy S20 Ultra (Otterbox Symmetry) and the Mate 9X Lite ("Fashion Design Personality Case"). Both are not what I was looking for - the gap is fixable with a 3d printed placeholder, however, due to PP being wider, you just can't put the phone face down in the case - not even thinking about dropping it. Hence, you never get any kind of Otterbox-like experience. :-(
Any suggestions for other phone models with a similar depth of the PP?
I guess I will have to try one of the fully 3D printed ones. Any recommendations regarding the material?
Other than that, I thought about getting the Otterbox Defender (Pro) for the S20 Ultra and "hacking" it.
If I were going to print a case I would make a TPU inner soft 'bumper' case and a nylon outer hard shell though ABS filament is also tough and easier to find.
There is a linked model for a 'negative' above so it should be pretty easy to use that to remove the shape from a simple shell on OpenSCAD or whatever you use.  You just need to add through holes for switches, USB and audio.
Hi all, a leather flip case for PinePhone Pro, does anything like that exist?
I see www.fitbag.com can make a case for the PPP but it looks like it can fall out because there is no closure, and the fabric looks soft.
@User 16030 which case did you use in https://forum.pine64.org/showthread.php?...4#pid68604 ?
I'd like to create my own in genuine leather, but raw materials are rather expensive, unfortunately. And, I don't know if it's worth going straight to synthetic leather when I'd like to keep a spirit of authenticity all the same for my Pinephone. Any recommendations?
Just in case there is someone else out there looking for a cheaper close-enough fitting case, I can confirm that this Otterbox case for the Moto G7 Power works:
https://www.amazon.com/OtterBox-Commuter...B07QWQKPQK
The side buttons are slightly misaligned, but I managed to work around this by carving the existing button indentations on the inner soft rubber portion of the case. The only other caveat is that the headphone jack alignment is slightly off, but the existing hole on the case could likely be expanded via a drill or dremel tool.
  Slip/Zippered Case for PP/KB? jakfish 0 281 03-03-2024, 04:55 PM
Last Post: jakfish
  keyboard case charging but not typing new2pinephone 18 5,784 02-19-2024, 07:30 AM
Last Post: theResonant
  PinePhone Dock with laptop? Mikey1977Y2J 2 636 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,170 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 451 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 515 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  Getting all keys working on pine phone keyboard-case undata 5 2,482 10-08-2023, 12:19 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,348 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,034 09-17-2023, 12:52 PM
Last Post: J T
