How to paste text in Plasma Mobile?
That's probably a pretty dumb question, but how do I paste text on Pinephone KDE (Manjaro/Plasma Mobile)?
Phosh for example offers within the keyboard's language selection the possibility to choose the terminal keyboard layout which offers the buttons Ctrl, Tab, etc.
But for Plasma Mobile I cannot find a solution. Tap and hold also has no effect.
So how do I paste text?
Thanks!!!
(11-11-2021, 02:41 PM)jojuma Wrote: So how do I paste text?
Hmm, what do you mean "paste"? Just checked and was able to copy a webpage text from Angelfish and paste it to Terminal or Spacebar or Nota or Phonebook Name field...
However - this does not seem to work for the Search field...
My experience with Manjaro PlaMo: https://forum.pine64.org/showthread.php?tid=15300
How do you paste it? Tap and hold the screen? Where do you get the option "paste"?
(11-12-2021, 08:07 AM)jojuma Wrote: How do you paste it? Tap and hold the screen? Where do you get the option "paste?
"Long touch" the text input field and a little pop-up menu appears where depending on the clipboard are small option icons: cut, copy and paste Wink
Running Manjaro PlaMo beta 8 + updates here.
I got the latest updates, too but that little pop-up menu you mention, doesn't appear for me...
At least I know now, how it should work and that I didn't do anything wrong since this is the intuitive way to paste text...
I'd recommend to try beta 8. Keep in mind that daily builds are not equal to beta+updates. Beta has its own update channel.
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,677 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,890 03-02-2023, 07:25 PM
  gnome-mobile dev Uturn 1 1,136 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 5,022 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,610 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 7,303 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 1,314 08-29-2022, 03:14 AM
Last Post: saddamus
  manjaro-pinephone / plasma-mobile-dev: Update broken Uturn 32 29,814 07-28-2022, 12:40 PM
Last Post: johaennessen
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,012 07-04-2022, 11:42 AM
Last Post: tuxmain
  Vivaldi Browser doesn't start keyboard for text entry tckosvic 1 2,037 05-24-2022, 11:32 PM
