phosh proximity sensor toggle script
id | grep root || sudo $0
NUMBER=`cat /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device2/in_proximity_scale`
if [ $NUMBER = 0.100000 ]
then
  echo turning off
  echo 6.4 > /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device2/in_proximity_scale
else
  echo turning on
  echo 0.1 > /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device2/in_proximity_scale
fi
works for me under manjaro phosh, YMMV
if it doesnt work see if that "iio\:device2" became device 1 or 0 or ...
is there an easy way to tie this to an icon?
Thank you for the script and the idea. Unfortunately, i don't know how to accomplish what you are looking for but i want to share my experience in toggling proximity sensor on my device.
In my case it was "iio\:device1"
I am also using Manjaro Phosh.
Additional note:
I had to run the command with sudo
sudo ./proximity-toggle.sh
The following is the script that toggles proximity sensor without problem:
[pp@pp-device ~]$ cat proximity-toggle.sh
NUMBER=`cat /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device1/in_proximity_scale`
then
  echo turning off
  echo 6.4 > /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device1/in_proximity_scale
else
  echo turning on
  echo 0.1 > /sys/module/stk3310/drivers/i2c\:stk3310/2-0048/iio\:device1/in_proximity_scale
fi
This isn't turning it off...
put "blacklist stk3310" inside "/etc/modprobe.d/proximity.conf" to permanently turn it off or do "sudo rmmod stk3310" to turn it off until reboot.
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 1,030 09-09-2023, 07:35 AM
Last Post: Manieck71
  Proximity lock on Plasma Mobile alpineduck 0 1,063 08-14-2023, 05:51 PM
Last Post: alpineduck
  How to disable lock screen in Phosh? lat 14 14,464 03-31-2023, 04:17 AM
Last Post: Eugo
  Fedora + Phosh for PinePhone njha 74 132,940 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,295 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 3,341 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 2,743 08-15-2022, 06:39 AM
Last Post: nemsys
  Building an image with phosh liara 1 1,840 02-01-2022, 08:26 AM
Last Post: kqlnut
  More useful terminal key layout for phosh's squeekboard Boern 21 27,586 01-15-2022, 02:35 PM
Last Post: gilwood
  Flat-file database script for pinephone terminal cabbie001 0 1,251 11-21-2021, 06:17 PM
Last Post: cabbie001
