keep getting thrown out of pinephone??!
Hello, I am new to this forum. I am running a pine phone beta addition with manjaro/plasma mobile. a lot of the time when I sign in i got locked out have to re sign in re do my pin password
(04-25-2021, 12:35 PM)radioheadfan Wrote: Hello, I am new to this forum. I am running a pine phone beta addition with manjaro/plasma mobile. a lot of the time when I sign in i got locked out have to re sign in re do my pin password
Are you saying your screenlock? Change your settings to make the screenlock timeout longer if you would like it to wait longer. Usually in power related settings.
- RTP
"In the beginner's mind there are many possibilities, in the expert's mind there are few." -Shunryu Suzuki
[ Pinephone Original | Pinetab v1 / v2 Enjoyer ]
Linux Device Privacy / Security Playlist
No I mean that it sends me to the lock screen randomly when I have just log in. I have changed it so it will not automaticaly switch of the screen but that has do nothing to help.
Maybe the same problem: https://forum.pine64.org/showthread.php?tid=13481
no it is completely chucking me of the phone and requireing me to log in/ input pin every few seconds.
(04-28-2021, 08:56 AM)radioheadfan Wrote: no it is completely chucking me of the phone and requireing me to log in/ input pin every few seconds.
That was very similar here Smile
What you can try is to connect charger - does the display stay on then?
If yes, you can try to manually edit the file: /.config/powermanagementprofilesrc to have similar values like in this post:
https://forum.pine64.org/showthread.php?...8#pid93468
to sii if that helps Wink
I have done that and download some updates which have been good to mean but the issue is some what still around.
I am having what you had in which it is fine and dandy when the charger is in but not so much when it is not.
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 253 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 551 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 1,201 12-09-2023, 01:26 AM
Last Post: crocspot
  pinephone 3 ideas aular 2 800 11-30-2023, 07:57 AM
Last Post: aular
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 1,989 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 1,327 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 1,812 10-03-2022, 05:53 AM
Last Post: unix21311
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,172 09-27-2022, 07:00 AM
Last Post: olyavi
  used PinePhone Mobian CE or PineTab CelynRollins 1 1,652 01-11-2022, 06:31 AM
Last Post: collierreinhold
  Are you OK with the size of the PinePhone? guenther 14 8,458 12-16-2021, 12:12 AM
Last Post: zetabeta
