Vcard contact list?
I put my Vcard contact list on the sd card mounted in my Mobian pinephone.
I can't figure out how to make the phone see the list.
Is there a folder I need to put the file in? If so, where is that located?
Thanks!
(03-12-2021, 11:24 AM)ncc Wrote: 1. sudo apt-get install evolution -y
2. click .vcf file to import contacts
3. sudo apt-get purge evolution -y && sudo apt-get autoremove -y
(import contacts via "evolution" and remove it after this is done)
Hmm. Got evolution open and can't figure it out. When I go to file, import. The program either freezes completely or I cannot select anything except back arrow.
you need a file explorer to click on your .vcf file (sudo apt-get install krusader -y)
Same issue. I get to the import data screen, can't see most of what's to the right (not sure if there is a horizontal scroll), "import data", ""import location", and "import data - vcard" are not selectable, only the back arrow. I appreciate your help, and don't want to wear on your patience.
(03-12-2021, 01:09 PM)ncc Wrote: 1. change the display scale in settings from 200% to 100% and you get a better view and can click the buttons
2. for long term use, enter in terminal "scale-to-fit krusader" and you get it squeezed into view
Rad. That worked. Thanks for being patient with the newb.
  Modem white list aular 7 1,009 02-13-2024, 04:35 PM
Last Post: aular
  List of Pinephone browsers Gamey 17 18,190 05-05-2022, 06:37 AM
Last Post: allworlds
  list of linux native apps/softwares for pinephone on the wiki alexandre 7 7,431 10-26-2021, 11:56 PM
Last Post: bcnaz
  Is there a priority list for features/ bugs, that have to be implemented/ fixed? stamat 17 13,689 06-03-2021, 10:30 AM
Last Post: stamat
  pinephone not on list of non-verizon kbdeamon 5 8,390 08-21-2020, 03:02 PM
Last Post: plainenough
  Next Pinephone Wish List and BraveHeart Feedback Starlord 0 2,080 02-22-2020, 03:54 PM
Last Post: Starlord
