Vcard contact list?
I put my Vcard contact list on the sd card mounted in my Mobian pinephone.
I can't figure out how to make the phone see the list.
Is there a folder I need to put the file in? If so, where is that located?
Thanks!
1. sudo apt-get install evolution -y
2. click .vcf file to import contacts
3. sudo apt-get purge evolution -y && sudo apt-get autoremove -y
(import contacts via "evolution" and remove it after this is done)
(03-12-2021, 11:24 AM)ncc Wrote: 1. sudo apt-get install evolution -y
Hmm. Got evolution open and can't figure it out. When I go to file, import. The program either freezes completely or I cannot select anything except back arrow.
you need a file explorer to click on your .vcf file (sudo apt-get install krusader -y)
Same issue. I get to the import data screen, can't see most of what's to the right (not sure if there is a horizontal scroll), "import data", ""import location", and "import data - vcard" are not selectable, only the back arrow. I appreciate your help, and don't want to wear on your patience.
1. change the display scale in settings from 200% to 100% and you get a better view and can click the buttons
2. for long term use, enter in terminal "scale-to-fit krusader" and you get it squeezed into view
(03-12-2021, 01:09 PM)ncc Wrote: 1. change the display scale in settings from 200% to 100% and you get a better view and can click the buttons
Rad. That worked. Thanks for being patient with the newb.
nice! thats what this is all about
  List of Pinephone browsers Gamey 15 3,096 06-04-2021, 11:22 AM
Last Post: ryo
  Is there a priority list for features/ bugs, that have to be implemented/ fixed? stamat 17 1,762 06-03-2021, 10:30 AM
Last Post: stamat
  list of linux native apps/softwares for pinephone on the wiki alexandre 4 1,358 01-05-2021, 07:48 AM
Last Post: alexandre
  Next Pinephone Wish List and BraveHeart Feedback Starlord 0 911 02-22-2020, 03:54 PM
Last Post: Starlord
