PinePhone power issues
Question
I have a UBports Edition, and the phone is having issues staying powered on. It'll run 5-60min then hard power off (on battery or cord or battery+cord). I have to remove from power (including battery) wait 5-15 min "rest period" then usually it'll only turn back on when power plug is inserted without battery. I'm suspecting something with power or heat, modem is a bit warm, would not call it hot. Has ran fine up until ~3 weeks ago (owned since April?).
I can't keep in on long enough to troubleshoot... I'm working on making a SD card image, but have experienced this issue with UBports and Manjaro.
Anyone experiencing? Anyone have suggestions?
(11-16-2020, 02:49 PM)Andrewjneumann Wrote: I have a UBports Edition, and the phone is having issues staying powered on. It'll run 5-60min then hard power off (on battery or cord or battery+cord). I have to remove from power (including battery) wait 5-15 min "rest period" then usually it'll only turn back on when power plug is inserted without battery. I'm suspecting something with power or heat, modem is a bit warm, would not call it hot. Has ran fine up until ~3 weeks ago (owned since April?).
Booted latest Manjaor from SD card and experience the same issue. Makes it maybe 15min before hard power off.
Update: I'm now unable to get booted on battery or cord or battery+cord. Experienced the same issue with Manjaro SD card boot as with UBports. I have reached out to support.
Worked with Pine support, after all the troubleshooting, a simple re-flash of the eMMC seems to have done the trick:" https://wiki.pine64.org/wiki/PinePhone#F..._Jumpdrive . I did have issues with low power usb port not allowing the eMMC to be seen by host os.
  PinePhone - boot from microSD laserpyramid 7 643 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 371 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 250 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,801 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,859 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 627 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,413 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 513 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,746 12-22-2023, 03:44 PM
  control power management aular 0 523 12-16-2023, 12:16 PM
Last Post: aular
