09-20-2020, 10:12 AM
Created a fresh install image this morning. unlike previous attempts, this fresh install now finds the sim card.
Thank you devs
Thank you devs
Fresh image, SIM card working
Thank you devs
09-20-2020, 01:00 PM
Sounds promising ) will try it this week .
Are sms and internet working ? Cheers Andi
09-20-2020, 11:35 PM
It does find the sim card for me but when i enter the PIN it doesn´t move on from there. Am i the only one with that problem? Checked the sim with Arch, works there.
09-21-2020, 01:45 AM
(09-20-2020, 11:35 PM)Veraendert Wrote: It does find the sim card for me but when i enter the PIN it doesn´t move on from there. Am i the only one with that problem? Checked the sim with Arch, works there.This is a sim pin? I don't use one, but I saw this on sfos fan club telegram group: "package to install: ofono-tests. Command: enter-pin pin <PIN>" and this lets you enter it. In any case my sim is recognised and 4g works ok but calls are tricky to make...lots of network connection errors...apart from quality.
09-21-2020, 06:11 AM
(This post was last modified: 09-21-2020, 07:45 AM by Veraendert.)
Thanks a lot. Will try.
Edit: Didn´t work so i removed the sim pin altogether. I can ring someone but unfortunately i´m then unable to hang up. Edit2: Works after trying for a 2nd time.
09-21-2020, 07:05 AM
Awesome !
I can send sms on 4G and 2G ... its the first distribution that worked (..for me). The only issues that I found was that I wasn't able to connect to the store .... I get a network error when I try to connect to it.
09-21-2020, 07:25 AM
(09-21-2020, 07:05 AM)Helium75 Wrote: Awesome ! With that error, it depends on how good of signal you are getting. I have tmobile, in the USA, and it's flaky in my house. when outside, calls and text messaging works. MMS does not work yet, but that's kind of to be expected.
09-21-2020, 07:41 AM
(09-21-2020, 07:25 AM)RodneyMyers Wrote: With that error, it depends on how good of signal you are getting.I've flashed to the emmc and it's quite a bit faster overall. Calls rarely work, or if they connect I can hear but the other person can't. SMS seems ok. Hopefully things will improve soon.
Well, the issue that I cant connect to the store happened while using WLAN .... havent tried calls yet, will test it later
edit: -> same here. Audio calls don't work ..... can't hear either side
09-21-2020, 09:05 AM
Works here too. First build with running SIM. Can make and receive calls and SMS. Caldav/Carddav also runs fine.
Now I am on testing this build |
Script not working | Andidoko | 4 | 1,611 |
04-09-2023, 12:03 PM Last Post: moodroid |
RAW image output only 32MB and not working | Kimberley van Buyten | 3 | 1,983 |
05-30-2022, 08:00 AM Last Post: acrux |
flash-it.sh script currently unable to create a SailfishOS image | acrux | 3 | 3,617 |
07-23-2021, 01:06 AM Last Post: OhneZ |
February image, upgrade to SFOS4 | defactofactotum | 8 | 7,837 |
02-24-2021, 09:45 AM Last Post: defactofactotum |
January image | defactofactotum | 8 | 9,340 |
01-08-2021, 10:27 PM Last Post: DrPhibes |
December image | defactofactotum | 3 | 5,079 |
12-16-2020, 05:35 AM Last Post: defactofactotum |
