Pinephone won't let me enter password
I updated my Pinephone tonight and when it restarted, I cannot enter the passphrase to boot the phone. It's like the keyboard doesn't work. This is the Mobian version.
Anybody know how to help me?
Thanks!
You did not mention if you are running from the eMMC or an sd card.?
The simplest GUI fix would be to just put on a whole fresh new install.
       "This is the Mobian version"    ?
   Mobian phone,  or  Mobian operating system,  or both.?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(09-01-2021, 12:50 AM)bcnaz Wrote: You did not mention if you are running from the eMMC or an sd card.?
Sorry for the missed info.
I am running from the phone, no sd card. This is the Mobian community edition, and I haven't changed anything.
Thank you.
Thank you.
There are multiple ways to 'fix' your phone. depending on your Linux experience.
My suggestion would be a fresh install of the nightly release.
 Simply download from the Mobian site, then use the jump drive method
to install it to your phone. If you do not want to run from an sd card.
 Pretty good instructions on doing that in the forum and the wiki.
I prefer running from the sd card as I change fairly often.
On my daily driver I change about every 3 to 6 weeks with updates inbetween.... My extra test phones I sometimes change daily.
  The latest Mobian release has reduced the power usage a lot.
Sent from a Manjaro Convergent phone running Mobian nightly release from September 1st on an sd card... using Pure Talk for my mobile data connection.
Good Luck !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Thank you.
Good Luck !
Thank you! I got it running again.
I have this problem periodically when I am too impatient to open the phone, especially after rebooting. If I wait until modem comes up (see bars) and the little ^ at bottom starts to wiggle, before swiping up, I never have a problem! Coincidence? Witchcraft? Not sure. Smile
Cheers,
TRS-80
Protocols, not Platforms
  Pinephone software Csanderson0313 3 1,431 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 84,940 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,790 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,284 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,261 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,533 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,999 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,608 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,072 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,136 10-21-2025, 12:12 PM
Last Post: Richy_T
