PinePhone as DIY SIP Gateway
Hi!
Today I thought of using my PinePhone as a SIP-Gateway. It might be an interesting usage of a PP.
I assume the AT-Commands are only used for commands and the high-bandwidth-stuff goes through another communication channel? What protocol is used for voice? Do you know existing OpenSource Software which could connect a EG25-G (or other modules) to SIP?
To be totally honest, I think the project will fail due to my time management, but still I am interested in gathering first information, maybe also for someone else who wants to continue it ...
Thanks!
Thomas
(08-21-2021, 05:57 AM)Thoams131 Wrote: Hi!
Thanks!
Thomas
There are SIP clients available, but none that work well yet - Twinkle, Linphone, etc. None have been optimized for mobile.
Hi!
I thought of a SIP Gateway, not a SIP-Client. Same Question here - sadly no good answer yet and some valuable comments are deleted
Seems like Asterisk is a commonly used Server-Software and there are some drivers for eg. Huawei Surfsticks available. So the only task would probably be to write a Module for the Baseband.
I think I currently won't have the time to make it, still some valuable input for someone else who considers doing it. (maybe my future self)
Best Regards!
Thomas
It used to be possible on the OpenMoko with asterisk. Have a look at chan-quectel which is targeting similar quectel modem modules, and seems a fair starting point:
https://github.com/t4rd15/asterisk-chan-quectel
The trick will probably be sorting out the audio routing/configuration - Megous has the best description I've seen of how the routing works, or at least can work - I'm not sure if the distros are all doing it the same way.
https://xnux.eu/devices/feature/audio-pp.html
  Pinephone software Csanderson0313 3 1,416 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 84,643 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,726 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,245 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,222 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,524 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,986 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,590 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,059 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,116 10-21-2025, 12:12 PM
Last Post: Richy_T
