Mobile network mode setting not saved
I've found that since there is still 3G service for now, my Pinephone running Mobian/Phosh will sometimes jump back and forth between 3G and 4G. Calling seems to be more reliable with 4G so I went into "Settings/Mobile/Network Mode" and changed that to "4G Only". A checkmark appears next to that, so then I tap the blue "Set" button and it changes and takes effect. However, that setting does not survive a reboot. The next time the phone is turned on the setting reverts to "2G, 3G, 4G (Preferred)".
Is this a bug or a feature, or am I missing something? Is there a way to retain this setting across reboots?
I'd say overall it's a bug - I can't see how you can spin forgetting user settings as a feature. Having said that I don't know if the settings are actually stored in a config file, or read out of the modem by ModemManager and assumed not to have been changed by anything else - eg25-manager being the most likely to do that. See https://gitlab.com/mobian1/issues/-/issues/253 for eg25-manager enabling GPS no matter the user's location settings.
resetting network mode has happened to me some cases, but not on every boot though.
i think network mode is stored in a modem, but modemmanager may have its own setting. modemmanager may mess the modem even it doesn't have the setting.
For Me :
On occasion I have had to reset the correct APN multiple times, but it does seem to eventually stick, and no problems after that.
*> BUT, I have only had that happen once in a while on a fresh installation.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Mobile internet via cellular network mostly not working Anna 18 26,852 01-19-2024, 02:59 AM
Last Post: anonymous
  Chatty does not work after suspend mode user641 4 7,069 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  ModemManager debug mode? (Needed to flash modem) calinb 1 5,771 02-27-2023, 04:18 PM
Last Post: calinb
  Not connecting to cellular network car46999 18 24,309 01-30-2023, 12:06 AM
Last Post: car46999
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,444 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 4,915 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 8,942 12-01-2022, 09:18 AM
Last Post: traut
  need help with downgradin network-manager Ferriah 0 2,322 11-07-2022, 04:51 PM
Last Post: Ferriah
  DNS Problems with Mobile Data arno_nuehm 29 40,550 10-29-2022, 09:16 AM
Last Post: treebeard
  spontaneous reboots in jumpdrive mode flynx 0 2,229 08-23-2022, 03:48 PM
Last Post: flynx
