Build Infinitime Sources
im a relative newbie to programming and wan't to have a own clock face.
I followed the build steps from Git - build and program and the build with a new face with some little changes was also successfull.[url=https://github.com/JF002/InfiniTime/blob/develop/doc/buildAndProgram.md][/url]
I wan't to programm the firmware by OTA/DFU, but my problem is, there wasn't a pinetime-mcuboot-app-dfu build.
The files build are:
  • pinetime-app-1.2.0.bin
  • pinetime-app-1.2.0.hex
  • pinetime-app-1.2.0.map
  • pinetime-app-1.2.0.out
The dependencies as descriped on git are installed and additionally adafruit-nrfutil.
I prepare the build with
cmake -DARM_NONE_EABI_TOOLCHAIN_PATH="/opt/gcc-arm-none-eabi/gcc-arm-none-eabi-10-2020-q4-major" -DNRF5_SDK_PATH="/opt/nRF5_SDK_15.3.0_59ac345" -DUSE_JLINK=0 -DNRFJPROG="/opt/nrfjprog/nrfjprog" -DCMAKE_BUILD_TYPE=Release -DBUILD_DFU=1 ../
and run the build with
make -j pinetime-app
 in the build-directory.
What have i done wrong. How to get an pinetime-mcuboot-app-dfu.zip?
thanks in advance
(07-22-2021, 01:40 PM)aemkai Wrote: Hello,
thanks in advance
add: cmake recognizes the DFU-Option as wanted:
* Build DFU (using adafruit-nrfutil) : Enabled
Hello, i found another issue.
Despite setting JLink-Option to "-DUSE_JLINK=0", the outprint is "Programmer/debugger : JLINK". Also, the CMake wants a path to NrfJprog. Could this be a reason?
Okay, problem is solved.
My mistake was to use
instead of
make -j pinetime-mcuboot_app
Build is running on the watch :-)
Quote:Build is running on the watch :-)
Awesome !
You can also type
make -j all
or just
make -j
to build all targets at once Wink
Working on InfiniTime, the FOSS firmware for the PineTime: https://github.com/InfiniTimeOrg/InfiniTime
Mastodon : https://mastodon.codingfield.com/@JF
Twitter : https://twitter.com/codingfield
Matrix : @JF002:matrix.org
  Infinitime Build problem BlackDev 1 4,082 12-23-2023, 08:07 AM
Last Post: Luno
  Bluetooth BLE-MIDI-controller app for PineTime / InfiniTime Luno 0 3,457 08-20-2023, 05:17 AM
Last Post: Luno
  Can't build InfiniTime Anonymous1 1 5,114 01-25-2023, 01:49 AM
Last Post: matthewfelgate
  error when try to build infinitime 1.10 gy145 2 6,411 07-08-2022, 08:23 PM
Last Post: gy145
  Daemon and go library to interact with InfiniTime on Linux Arsen6331 0 3,529 08-21-2021, 10:32 AM
Last Post: Arsen6331
Information InfiniTime Default Face USA Mod - No longer supported The3DmaN 1 5,358 02-25-2021, 03:51 PM
Last Post: The3DmaN
  InfiniTime Avamander 4 11,659 02-24-2021, 02:38 PM
Last Post: Avamander
  Build PineTime Firmware in the Cloud lupyuen 3 9,842 07-27-2020, 04:54 PM
Last Post: lupyuen
