phosh 11 stops dead at login after update
After, I believe, the second update on phosh 11 the system hangs at the manjaro login screen with the tiny characters before the numerical pad usually comes up. I haven't found any similar problems yet. Thanks for any advice or pointers towards resolving this problem.
Provided it is the same issue, here's what it looks like after the update. (See pic)  The font is 8pt? 6pt?
on Manjaro Plasma we do the following, we run another OS from the SD and everyday we boot from the eMMC connecting a keyboard via the dock, then we log in from the terminal you show in the photo and update manually, when the appropriate updates come it will boot again, it may take 2-3 days, the problem arises from partial updates which break the system
another way to connect to the phone is through the headphone UART cable
the internet connection is achieved through ethernet from the dock or by running the `nmtui` command to set up the wireless connection
  Using too much juice since last update Eugo 20 22,590 03-15-2024, 10:09 AM
Last Post: Eugo
  recent update Uturn 14 14,219 02-13-2024, 01:19 AM
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,732 04-25-2023, 09:49 AM
Last Post: jakfish
  Latest update Eugo 21 25,136 03-09-2023, 05:27 AM
Last Post: Eugo
  Discover - "He's dead, Jim" jojuma 7 8,933 03-06-2023, 08:11 PM
Last Post: rocket2nfinity
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,596 02-24-2023, 12:56 PM
Last Post: jakfish
  Firefox issue with latest update Barugon 6 8,563 01-28-2023, 01:29 AM
Last Post: alaraajavamma
  What is the easiest way to login? shengchieh 2 3,645 01-21-2023, 07:08 PM
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 2,972 10-10-2022, 12:53 PM
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 5,874 09-05-2022, 03:42 PM
Last Post: nroth
