Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted!
(06-28-2021, 07:31 AM)jfenn2199 Wrote: Got mmsd-tng installed from sid and pulling MMS messages to Modem Manager with SMSWAP set to true.  Can confirm Mint Mobile (US T-Mobile MVNO) works. Oddly Mobian defaults Mint mobile sim to T-Mobile's mobilenet APN so had to change the apn for the modem to
Name: Internet/MMS2 APN: Wholesale
and ~/.mms/modemmanager/mms
[Modem Manager] CarrierMMSC=http://wholesale.mmsmvno.com/mms/wapenc MMS_APN=Wholesale CarrierMMSProxy=NULL DefaultModemNumber=NULL AutoProcessOnConnection=true AutoProcessSMSWAP=true [Settings] UseDeliveryReports=false TotalMaxAttachmentSize=110000 MaxAttachments=25 AutoCreateSMIL=false
Running into redirect issues attempting to clone chatty from the /wip/sadiq/mm-account branch.  Going to attempt the python messenger method to verify completed delivery. But great news is 18 hours on and my modem hasn't clogged or crashed.  Thanks for the great work.
I'm on Mint Mobile as well. My ~/.mms/modem manager/mms file matches yours, but my apn settings are Name: Ultra, APN: Wholesale.
I'm able to receive MMS in the newly compiled chatty app (the MMS wip Branch), but only if the original Chatty is uninstalled. Any text sent through the branched Chatty is sent twice for some reason.
Thank you I will try that tonight.  Ran into syntax errors attempting to run the python-messaging method from the wiki.
Successfully compiled chatty from the wip/sadiq/mm-account (still encountering redirect error via git clone but was able to download the branch as a tar.gz and compile from that) branch and received all MMS messages from Sunday to today (including a group message which I was unknowingly added to Sunday.
Interestingly enough I tried to test installing on an SD card and using the same mobian-installer-pinephone-phosh-20210516.img which I flashed my phone with and following the same processes of sudo apt update + sudo apt upgrade + reboot after initial install then changing sources.list from Bullseye to unstable, then update/upgrade/reboot again, and finally installing mmsd-tng and setting my apn the same as my primary install (except using Ultra name as 0x007 so will test with my Internet/MMS2 naming and edit this report) resulted in the non-matching modem number error and threw an error on receiving messages in systemctl status check (will add error when testing with Internet/MMS2 name on APN).
@kop316
Thank you for all your hard work! This is incredible!
I've been able to get so far on my own and was hoping somebody else could please help me finish.
I'm running Mobian on the Verizon network and so far have done this:
Installed mmsd-tng through Mobian's sid repository # mmsd-tng version 1.0~beta4
Compiled and built the wip/sadiq/mm-account chatty
Edited the /home/mobian/.mms/modemmanager/mms file as follows:
[Modem Manager] CarrierMMSC=http://mms.vtext.com/servlets/mms MMS_APN=vzwinternet CarrierMMSProxy=NULL AutoProcessOnConnection=true AutoProcessSMSWAP=false
When I run mmsdtng -d, I'm able to see that MMS are coming in but that's as far as it goes for me.
mmsd-tng[3324]: MMS transaction id: 22EC5E8C380000004AB0000201 mmsd-tng[3324]: MMS version: 1.0 mmsd-tng[3324]: From: xxxxxxxxxx/TYPE=PLMN # phone number redacted mmsd-tng[3324]: Subject: (null) mmsd-tng[3324]: Class: Personal mmsd-tng[3324]: Size: 30720 mmsd-tng[3324]: Expiry: 2021-07-07T18:05:17-0400 mmsd-tng[3324]: Location: http://63.55.224.23/servlets/mms?message-id= mmsd-tng[3324]: ../src/service.c:mms_service_push_notify() about to store_meta_open 2 mmsd-tng[3324]: ../src/service.c:mms_service_push_notify() did store_meta_open 2 mmsd-tng[3324]: ../src/service.c:mms_service_push_notify() did create_request mmsd-tng[3324]: ../src/service.c:activate_bearer() service 0x5598f905c0 setup 0 active 0 mmsd-tng[3324]: ../src/service.c:activate_bearer() service 0x5598f905c0 waiting for 20 seconds mmsd-tng[3324]: ../plugins/modemmanager.c:set_context() Setting Context... mmsd-tng[3324]: ../src/service.c:mms_service_set_mmsc() service 0x5598f905c0 mmsc http://mms.vtext.com/servlets/mms mmsd-tng[3324]: ../plugins/modemmanager.c:set_context() Max number of bearers: 1 mmsd-tng[3324]: ../plugins/modemmanager.c:set_context() Current Context APN: vzwinternet, mmsd-tng settings MMS APN: vzwinternet mmsd-tng[3324]: ../plugins/modemmanager.c:set_context() You are connected to the correct APN! Enabling context... mmsd-tng[3324]: ../plugins/modemmanager.c:bearer_handler() At Bearer Handler: path /org/freedesktop/ModemManager1/Modem/1 active 1 context_active 1 mmsd-tng[3324]: ../plugins/modemmanager.c:bearer_handler() active and context_active, bearer_notify mmsd-tng[3324]: ../src/service.c:mms_service_bearer_notify() service=0x5598f905c0 active=1 iface=wwan0 proxy=(null) mmsd-tng[3324]: ../src/service.c:mms_service_bearer_notify() interface wwan0 proxy (null) mmsd-tng[3324]: ../src/service.c:mms_service_bearer_notify() Proxy is set to 0 mmsd-tng[3324]: ../src/service.c:process_request_queue() service 0x5598f905c0 mmsd-tng[3324]: ../src/service.c:process_request_queue() location http://63.55.224.23/servlets/mms?message-id= mmsd-tng[3324]: ../src/service.c:resolve_host() Binding resolver queries to interface wwan0 mmsd-tng[3324]: ../src/service.c:resolve_host() All Nameservers: 2001:558:feed::1,2001:558:feed::2,2001:4888:34:ff00:386:d::,2001:4888:35:ff00:383:d::,75.75.75.75,75.75.76.76,198.224.144.135,198.224.145.135 mmsd-tng[3324]: ../src/service.c:resolve_host() IPv6 Nameservers: 2001:558:feed::1,2001:558:feed::2,2001:4888:34:ff00:386:d::,2001:4888:35:ff00:383:d:: mmsd-tng[3324]: ../src/service.c:resolve_host() Only using ipv6 nameservers mmsd-tng[3324]: Failed to resolve host: Domain name not found mmsd-tng[3324]: ../src/service.c:resolve_host() Unable to resolve host to IPv6, retrying with IPv4... mmsd-tng[3324]: ../src/service.c:resolve_host() Restoring original list of nameservers mmsd-tng[3324]: ../src/service.c:resolve_callback() Found IP for '63.55.224.23': 63.55.224.23 mmsd-tng[3324]: ../src/service.c:resolve_host() Using URI for request: http://63.55.224.23/servlets/mms?message-id= mmsd-tng[3324]: ../src/service.c:soupmessage_network_event_cb() Socket is bound to wwan0 > GET /servlets/mms?message-id= HTTP/1.1 > Soup-Debug-Timestamp: 1625263538 > Soup-Debug: SoupSession 1 (0x559901e220), SoupMessage 1 (0x5598f9e0d0), SoupSocket 1 (0x7f8c023db0) > Host: 63.55.224.23 > Accept-Encoding: gzip, deflate > Connection: Keep-Alive < HTTP/1.1 404 Not Found < Soup-Debug-Timestamp: 1625263538 < Soup-Debug: SoupMessage 1 (0x5598f9e0d0) < Server: Apache < Content-Type: text/html < Date: Fri, 02 Jul 2021 22:05:38 GMT < Connection: Keep-Alive < Content-Length: 0 mmsd-tng[3324]: Fail to get data (http status = 404) mmsd-tng[3324]: ../src/service.c:on_message_done() status: 404 mmsd-tng[3324]: ../src/service.c:on_message_done() data size = 0 mmsd-tng[3324]: ../src/service.c:on_message_done() request->result_cb=0x558744f914 vs. retrieve_conf=0x558744f914/send_conf=0x558744a470/notify_resp=0x558744cb20 mmsd-tng[3324]: Fail to get data (http status = 404) mmsd-tng[3324]: retry later
Thank you again!
I also use Mint and I've tried off and on to get mmsd working but it never quite worked right. The messages would show in ~/.mms/modemmanager/ but when I tried to read them with any of the options listed on the mobian wiki there was always an error. Well, when I read through your settings I realized what my issue might be. I had been setting MMS_APN to Mint or MintMMS instead of setting it to the APN for data which is Wholesale. When I did that and restarted mmsd, it processed through all my mms messages sitting in ~/.mms/modemmanager and they popped right up in my compiled version of chatty. So, thanks for sharing!
After getting mms setup on mobian, I decided to try my luck on setting everything up on my preferred pinephone distro (I run arch btw). While getting mmsd setup I built vgmms (https://git.sr.ht/~anteater/vgmms) on my pinebook pro (it took 40 minutes but that's still less than half the time it takes to build on the pinephone). Vgmms is pretty barebones and doesn't seem to display your contacts names, but it does send and receive picture messages and group chats along with regular sms. It's also snappier than chatty. Has anyone else tried out vgmms? Are there other alternative chat programs out there?
Thanks to everyone who's worked to get this as far as we are now!
I've installed the latest mmsdtng (beta5) and I'm running into this dbus error when I start.
$ mmsdtng -d
mmsd-tng[8136]: MMSD-TNG version 1.0~beta5
mmsd-tng[8136]: Lost Dbus Connection! Exiting....
I seem to have the dbus service running so I'm not sure what's happening. Any ideass?
I used the d-feet utility to determine that ModemManager is using the name "org.freedesktop.ModemManager1" on the system bus and mmsd-tng is using the name ".ModemManager". For some reason maybe these are conflicting? Not sure, and not sure what to do about it yet.
Just following up on my own post, I was trying to start mmsdtng as root, which won't work due to not being attachable to the user's d-bus session.  I set up an XDG autostart using the file from here: https://pkgs.alpinelinux.org/contents?br...=community to /etc/xdg/autostart/mmsd.desktop.  Then reboot, and that should do it.
So I uninstalled Chatty and installed the MMS WIP branch but now I can't see chatty anywhere. I followed all the steps from the wiki installing Chatty but still am not seeing a chatty app. Is there something I'm missing?
You'll be able to run chatty from the build directory in the chatty directory, so assuming downloaded and built in home folder
sh ~/chatty/build/run
On debian I was unable to build a .deb using gpb as directed but was able to use Ninja to install.  So from the ~/chatty/build directory
ninja install
And reboot.  Then you should have your chatty launcher back and be able to receive notifications for SMS messages like normal (at this time I'm not getting notifications on MMS messages).
Make sure that if your settings in ~/.mms/modemmanager/mms have
then change that to
and with that you should have full MMS messages rolling into chatty.
  Solutions to modem / connection problems Anna 4 7,577 09-13-2026, 07:52 AM
Last Post: idice
  Latest firmware for PinePhone modem! Subsentient 106 249,235 04-03-2026, 08:37 AM
Last Post: baptx
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 1,463 11-17-2025, 07:49 AM
Last Post: danm1988
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 9,242 10-18-2023, 08:37 AM
Last Post: luppivega
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 5,031 04-10-2023, 10:19 PM
Last Post: lupyuen
  changing from bullseye to bookworm to install mmsd-tng jyoung 8 10,158 04-09-2023, 06:08 PM
Last Post: zetabeta
Sad Modem is always visible/connected but stops working after a while dante404 6 8,790 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 7,016 10-25-2022, 05:28 PM
  Pinephone: OpenGL support? orbital 2 5,407 08-25-2022, 04:09 PM
Last Post: vortex
  Which PP OS currently has the best podcast support? kujo_marble 3 5,693 07-14-2022, 07:09 AM
