sudo broke - "/usr/bin/sudo must be owned by uid 0 and have the setuid bit set"
I don't have half a clue how this happened.  I was trying to install BitWarden desktop app from source and ran into a few snags with node-gyp during build
Below is just some random stuff I was doing in the terminal.
On the first line below, sudo worked. On the last line, sudo suddenly failed and has been broken ever since.  Either something I did in the log below somehow broke sudo, or something in the background of PMOS broke it.
Any idea what's going on here?  Is there any way to recover other than wiping my phone and reinstalling?
This is a mostly clean install.. PMOS only on the device for about 1 hour, and I only installed some dev libs, git.. basic stuff.
PMOS 21.03.1
pine64-pinephone:~/Source/desktop$ sudo npm install node-gyp -g
added 91 packages, and audited 92 packages in 25s
3 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
pine64-pinephone:~/Source/desktop$ node-gyp rebuild
gyp info it worked if it ends with ok
gyp info using node-gyp@8.1.0
gyp info using node@14.16.1 | linux | arm64
gyp info find Python using Python version 3.8.10 found at "/usr/bin/python3"
gyp info spawn /usr/bin/python3
gyp info spawn args [
gyp info spawn args   '/usr/lib/node_modules/node-gyp/gyp/gyp_main.py',
gyp info spawn args   'binding.gyp',
gyp info spawn args   '-f',
gyp info spawn args   'make',
gyp info spawn args   '-I',
gyp info spawn args   '/home/user/Source/desktop/build/config.gypi',
gyp info spawn args   '/usr/lib/node_modules/node-gyp/addon.gypi',
gyp info spawn args   '/home/user/.cache/node-gyp/14.16.1/include/node/common.gypi',
gyp info spawn args   '-Dlibrary=shared_library',
gyp info spawn args   '-Dvisibility=default',
gyp info spawn args   '-Dnode_root_dir=/home/user/.cache/node-gyp/14.16.1',
gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/node-gyp',
gyp info spawn args   '-Dnode_lib_file=/home/user/.cache/node-gyp/14.16.1/<(target_arch)/node.lib',
gyp info spawn args   '-Dmodule_root_dir=/home/user/Source/desktop',
gyp info spawn args   '-Dnode_engine=v8',
gyp info spawn args   '--depth=.',
gyp info spawn args   '--no-parallel',
gyp info spawn args   '--generator-output',
gyp info spawn args   'build',
gyp info spawn args   '-Goutput_dir=.'
gyp info spawn args ]
gyp: binding.gyp not found (cwd: /home/user/Source/desktop) while trying to load binding.gyp
gyp ERR! configure error
gyp ERR! stack Error: `gyp` failed with exit code: 1
gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/node-gyp/lib/configure.js:353:16)
gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:277:12)
gyp ERR! System Linux 5.11.0
gyp ERR! command "/usr/bin/node" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /home/user/Source/desktop
gyp ERR! node -v v14.16.1
gyp ERR! node-gyp -v v8.1.0
gyp ERR! not ok
pine64-pinephone:~/Source$ cd ..
pine64-pinephone:~/Source$ find . -name "binding*"
./node-gyp/docs/binding.gyp-files-in-the-wild.md
./node-gyp/test/node_modules/hello_world/binding.gyp
pine64-pinephone:~/Source$ cd node-gyp/test/node_modules/hello_world/
pine64-pinephone:~/Source/node-gyp/test/node_modules/hello_world$ node-gyp rebuild
gyp info spawn args   '/home/user/Source/node-gyp/test/node_modules/hello_world/build/config.gypi',
gyp info spawn args   '-Dmodule_root_dir=/home/user/Source/node-gyp/test/node_modules/hello_world',
internal/modules/cjs/loader.js:883
  throw err;
Error: Cannot find module 'nan'
Require stack:
- /home/user/Source/node-gyp/test/node_modules/hello_world/[eval]
    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:880:15)
    at Function.Module._load (internal/modules/cjs/loader.js:725:27)
    at Module.require (internal/modules/cjs/loader.js:952:19)
    at require (internal/modules/cjs/helpers.js:88:18)
    at [eval]:1:1
    at Script.runInThisContext (vm.js:133:18)
    at Object.runInThisContext (vm.js:310:38)
    at internal/process/execution.js:77:19
    at [eval]-wrapper:6:22
    at evalScript (internal/process/execution.js:76:60) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [ '/home/user/Source/node-gyp/test/node_modules/hello_world/[eval]' ]
gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
gyp ERR! cwd /home/user/Source/node-gyp/test/node_modules/hello_world
gyp ERR! not ok
pine64-pinephone:~/Source/node-gyp/test/node_modules/hello_world$ sudo apk add g++
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
pine64-pinephone:~$ ls -l /usr/bin/sudo
-rwxr-xr-x    1 root     1000        141224 Jan 26 19:06 /usr/bin/sudo
Any help appreciated.  Thanks
Hi, not sure how that could have happened, but it should be easy to fix.
As the error message suggests, you have to set the setuid bit. This is what allows the `sudo` binary to elevate its privileges.
To do so, you need to become root first, and since `sudo` is broken you have to use `su`. After that run the following command:
chmod u+s /usr/bin/sudo
The error message also says that `sudo` must be owned by uid 0 (root). Yours is owned by uid 0, but the group is set to gid 1000, so you might also want to change that to 0, although it's probably not necessary:
chown root:root /usr/bin/sudo
Hope that fixes it.
(07-07-2021, 04:26 AM)jlucas Wrote: Hi, not sure how that could have happened, but it should be easy to fix.
Hope that fixes it.
Thank you.  I ended up wiping the phone.  I tried su, but I couldn't get it to accept a password.  I tried my lockscreen password as well as the default 147147.
Weird issue
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 11,023 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Can't find "sudo gedit" alternative mh4it 3 7,158 09-10-2020, 03:48 AM
Last Post: User 18618
