firefox-esr stopped working after June 18 update
I have the same issue (NS_ERROR_NET_INADEQUATE_SECURITY on most sites).
Some web searches gives that this might be related to an incompatibility with libnss. Although this bug report concerns Thunderbird, it's probably related, and the solution would then be to install libnss3 2:3.66-1. Unfortunately the only version available for the PinePhone today seems to be 2:3.61-1:
mobian@mobian:~$ apt-cache policy libnss3
libnss3:
  Installed: 2:3.61-1
  Candidate: 2:3.61-1
  Version table:
*** 2:3.61-1 500
        500 http://deb.debian.org/debian bullseye/main arm64 Packages
        100 /var/lib/dpkg/status
(06-20-2021, 10:32 PM)ryo Wrote: As per: https://blog.kanbanmart.com/entry/firefox_error_http2
1. Go to "about:config".
2. Accept the warning.
3. Search for "network.http.spdy.enabled.http2".
4. Set the value to "false".
That worked on my end, as I got the same error.
it worked.
Thanks!
I had the same issue on my PineTab....in firefox on my linux mint desktop http2 is enabled but no problems with any sites. Hm?
(06-28-2021, 02:12 AM)guenther Wrote: I had the same issue on my PineTab....in firefox on my linux mint desktop http2 is enabled but no problems with any sites. Hm?
It's because the problem is not http/2 but seems to be an incompatibility between Firefox and the libnss3 version that Mobian uses right now.
@bitnick Thank you for clarification!
(06-30-2021, 09:29 AM)guenther Wrote: @bitnick Thank you for clarification!
Yes, thanks! Smile
looks like libnss was updated today in unstable and seems to have corrected the problem.
(07-20-2021, 02:17 PM)jfenn2199 Wrote: looks like libnss was updated today in unstable and seems to have corrected the problem.
It's now also in stable, updated, changed option back to enabled, restarted Firefox, everything works. Smile
  No touch KB after update(forky) biketool 4 2,535 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 3,075 10-22-2025, 07:14 AM
Last Post: anonymous
  New camera app gnome-snapshot working on trixie? vusra 4 4,938 04-11-2025, 02:53 AM
Last Post: vusra
  how to update mobian over tor vusra 14 20,522 12-04-2024, 07:01 PM
Last Post: vusra
  Calls 4G not working oliwierzgorniak 2 5,506 08-06-2024, 02:20 PM
Last Post: baptx
  Mobile internet via cellular network mostly not working Anna 18 26,852 01-19-2024, 02:59 AM
Exclamation The internal speaker stops working anonymous 6 7,839 01-17-2024, 05:53 PM
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 2,245 08-30-2023, 03:23 PM
Last Post: jojuma
  Wifi doesn't work after update nickolas 2 4,828 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 5,004 03-17-2023, 07:26 AM
