How to backup Contacts in Gnome / Posh ?
In order to investigate issues I want to change my linux distribution so I need to export (then import) my contacts.
I am currently using Mobian with Posh, my contacts are in the application Gnome Contacts 3.38.1.
I see no option to export a vcf file.
I would be happy with copying a configuration directory (like how you can backup ~.mozilla/firefox)
Any idea ?
(06-26-2021, 10:02 AM)gab Wrote: ... so I need to export (then import) my contacts.
Your contacts will be in ~/.local/share/evolution/
You can either copy/restore that directory if you go to another gnome based distro. And/or install evolution and do a backup from there.
HTH
Ok, thank you for this answer.
It worked for me. I had to reboot the phone for the contacts to become visible in the Contact application: it does not seem to reload the contacts automatically.
  Filen.io(and others) a useful backup, cloud storage, and sharing tool biketool 0 3,768 01-12-2025, 11:25 AM
  how to backup user data? Uturn 1 2,802 08-30-2023, 05:23 AM
  Basic question: KDE apps on GNOME and vice versa jojuma 4 5,010 06-15-2023, 01:42 PM
Last Post: jojuma
  gnome-online-accounts won't sign in to google account [SOLVED] pjsf 0 6,439 04-27-2022, 07:32 PM
Last Post: pjsf
  Importing Contacts gilwood 4 6,815 01-26-2022, 04:03 PM
Last Post: TRS-80
  Best way to manage multiple OS installations (backup, flash) 3x5co 2 5,860 02-08-2021, 09:28 PM
Last Post: C0ffeeFreak
Question manjaro, dial app <---> contacts app tommaso 0 2,621 11-23-2020, 01:46 AM
Last Post: tommaso
