Dependency resolution failed
Tried to update my beta edition phone this morning, using Discover.
There are 623.2MB of updates, held up by libcanberrra=0.30+2+gc0620e4-3 Looks like this is a sound library
Anyone know a way around this?
(06-19-2021, 01:29 PM)nelstomlinson Wrote: Tried to update my beta edition phone this morning, using Discover.
Use the terminal and type:
sudo pacman -Syyu (and follow the instructions on the screen)
I did my 2G new pinephone this morning.
It's downloading stuff now, looks like that is working.  Libcanberra is getting replaced by /extra/libcanberra, and there were a couple of others like that. I said Y to all.
Still trying to figure out Manjaro, obviously.
I found the Manjaro and Arch wiki entries for pacman at
https://wiki.manjaro.org/index.php?title...n_Overview and
https://wiki.archlinux.org/title/Pacman
So now I have some reading to do.
Edited to add: that worked, and the update doesn't seem to have broken anything much, though firefox again doesn't pull up the keyboard.
(06-19-2021, 06:24 PM)RRman Wrote: So what the heck is the password I need to enter to sudo? I don't recall explicitly setting anything. And yes, I am a total newbie!
If you using Manjaro try 123456 unless you change it.
Have a look at this: https://wiki.pine64.org/wiki/PinePhone_S...anjaro_ARM
Thank you! Will check that out and give it a try.
(06-26-2021, 03:59 PM)dgiffin Wrote: Thank you! Will check that out and give it a try.
No joy :-( So what, do I need to reset something and try again? I've not done anything on the phone that I would need to keep.
Try the code you use to initially setup your phone(if you using Manjaro Plasma).
Still no joy - I've tried the only password I setup and the ones listed on that wiki page - I obviously have a crap memory :-( So how do I reset this back to the initial state and go through the whole setup routine again?
(07-03-2021, 08:16 AM)mouffa Wrote: on Manjaro Plasma it is the same password you use to unlock the screen
Really? I thought I had tried that, but maybe not, will give that a go - many thanks!
Thank you, worked perfectly! ?
  How to find and remove junk files from failed updates? danimations 4 7,061 10-24-2021, 11:25 PM
Last Post: danimations
  External Display Resolution Change TheBlindEarthican 3 9,350 12-08-2020, 05:21 AM
Last Post: hobbitus
