Image Roll - new image viewer for phosh/gnome
Hi everyone,
I have created a new image viewer which can be used over the stock one.
UI was created with linux phones in mind, it can also do basic image editing.
You can install the flatpak from here: https://flathub.org/apps/details/com.git....ImageRoll
Repository: https://github.com/weclaw1/image-roll
In the future I will try to add it to linux distros repositories.
Let me know what you think and how I can improve it.
(06-12-2021, 05:19 PM)weclaw Wrote: Hi everyone,
Hi Weclaw,
I am not familiar with Mobian, just started a bit. I could install it and it runs fine.
I would like to have an overview of pictures of an folder as a preview. And the option to delete pictures. And maybe to see the file-name of the opened picture.
If a picture is opened via fit screen and I zoom it to e. g. 20% it is not possible to see "fit screen" in menu which is the most important one.
Thank you for the work!
best regards
Ralf
Thank you for creating this app, I love it! I've already added it to https://linmobapps.frama.io!
(06-13-2021, 07:26 AM)Ralf Wrote: Hi Weclaw,
best regards
Ralf
Displaying of file names is something I will add in the next release, option to delete pictures will also be implemented, but most likely at a later release.
The problem with zoom is a bug which will have to be fixed by using libhandy or migration to GTK4.
  Fedora + Phosh for PinePhone njha 77 234,233 01-14-2026, 12:22 AM
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 3,440 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 28,173 03-31-2023, 04:17 AM
Last Post: Eugo
  Mepo - Minimalist and hackable OSM map viewer for mobile linux mil 22 33,088 10-31-2022, 07:29 AM
Last Post: mil
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 6,420 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 8,994 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 5,629 08-15-2022, 06:39 AM
Last Post: nemsys
  Most Power Efficient OS Image jwinarske 0 2,207 07-05-2022, 07:05 PM
Last Post: jwinarske
Photo GNOME Display Orientation Unregistered Guest 0 2,083 05-20-2022, 06:09 AM
Last Post: Unregistered Guest
  Building an image with phosh liara 1 4,225 02-01-2022, 08:26 AM
Last Post: kqlnut
