22 July 2116 -- wrong Date & Time
Hi guys,
once every few days, sometimes weeks, my phone's system time leaps to 22 July 2116, which of course has a lot of side effects (on axolotl, geary, calendar and so on).
Has anybody else experienced this? And is there a fix?
Best, Anna
(05-31-2021, 09:09 AM)Anna Wrote: Hi guys,
Best, Anna
I don't have this exact issue, but I do get the time mess up. What I've noticed with the time messing up is: sometimes my phone locks up, and I can't get the screen to turn on. I end up resetting it by holding down the power button for 15 seconds. I noticed that if I do this out of range of my wifi network, the time can switch to a few hours previous to the current time. Sometimes the date gets messed up. If I don't do anything else, it never fixes itself until I get back in range of my wifi network. It's like it only syncs the time over wifi. I think the time should sync with the phone network time, not the wifi network time.
This was fixed with a recent kernel patch https://lore.kernel.org/linux-sunxi/2021...and.org/T/
You can apply the patch and recompile the kernel https://gitlab.com/mobian1/wiki/-/wikis/Kernel-Build
Distributions based on the megous kernel have the patch already. https://github.com/megous/linux/releases...10519-1214
Manjaro, Arch Linux Arm, have the patch. U-Boot has also been patched, it would sometimes hang at boot without it.
(05-31-2021, 07:30 PM)8bit Wrote: This was fixed with a recent kernel patch https://lore.kernel.org/linux-sunxi/2021...and.org/T/
thank you! great info!
Although....I have to admit, I have no idea how to recompile a kernel - any chance I can just get the update through the plasma discover app? If not, don't worry about it, I'll just wait for the fix to become "general".
ok, maybe I spoke too soon- I looked at your https://gitlab.com/mobian1/wiki/-/wikis/Kernel-Build - it actually looks do-able. I will study that and see if it's something I can do..... thank you!
(05-31-2021, 07:41 PM)mudflap Wrote: thank you! great info!
You could open an issue on Mobian https://gitlab.com/mobian1/devices/sunxi...obian-5.10
Best, Anna
I simply set the correct time and date in settings,    and turn off the 'Automatic Date & Time'
Even after reboots and updates it keeps showing the correct time.
Unless you are crossing time zones  often ?   That should work until the Dev's  get that resolved.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Thank you guys!
Switching off Automatic Date and Time seems straightforward enough.
I wonder whether the issue might already be resolved: I haven't encountered any problems since my post and recently there have been so many updates and so many great improvements that I am presently really happy with my phone. Heart Heart Heart
I have been doing that for months and I have not noticed any negative effects,
While I do regular 'updates' I also do complete fresh installs pretty often.
BUT I am also still running from the sd card.... I still have the Post Market OS on the eMMC from the factory.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 8,054 04-26-2024, 04:56 PM
Last Post: zetabeta
  [solved] Black screen at boot time mdk 0 2,795 01-13-2023, 03:33 AM
Last Post: mdk
  Time is wrong after reboots stucked at 27th august user641 2 4,165 09-08-2022, 01:39 PM
Last Post: user641
  Date & Time-setting app is a very poor design treebeard 6 8,556 07-27-2022, 06:35 AM
  Header bar date/time vs time-only option Korac 2 4,446 01-17-2022, 10:02 AM
Last Post: Korac
  Axolotl on Mobian. What am I doing wrong? quixote 3 6,463 05-11-2021, 06:09 PM
Last Post: quixote
  Wrong location / place by GPS - Location Services - GNSS - Maps Anna 17 25,116 03-22-2021, 12:42 PM
Last Post: Maus
  Re-do First Time Setup / Location Services Setting (How?) calinb 3 7,603 01-01-2021, 08:03 PM
Last Post: calinb
  "Oh no, Something has gone wrong, Logout" pajux 11 21,874 11-12-2020, 05:22 PM
Last Post: pajux
  What am I doing wrong with Geary ? wi_badger 3 10,503 09-16-2020, 06:34 AM
Last Post: m.alizade7
