Will the Pinephone work with Vodafone in Romania?
I’m planning to order a Pinephone Beta soon (150$ version). In my case I live in Romania and my cellphone provider is Vodafone. I can't quite remember or tell if it's a sim card or microsim, hopefully I'll fine either way? I wanted to be sure others with this provider can confirm everything works fine... by everything meaning at least calls, SMS, and 3G / 4G internet (I don't use MMS). So to EU users of the Pinephone, what's your experience with Vodafone SIM cards?
(05-26-2021, 07:23 PM)MirceaKitsune Wrote: I can't quite remember or tell if it's a sim card or microsim, hopefully I'll fine either way?
The PinePhone takes the micro-SIM form factor, but the package includes (or at least used to) a nano-SIM to micro-SIM adapter (literally just a piece of plastic that you put your nano-SIM into) but I recall some posts on the forums saying it's a bit crap. A standard-sized SIM card won't fit into the PinePhone  but you may be able to cut away some of the excess plastic to make it into a micro-SIM, some phone stores even offer to do that for you, but I wouldn't recommend that either as you risk damaging the electronics inside the SIM card.
(05-26-2021, 07:23 PM)MirceaKitsune Wrote: So to EU users of the Pinephone, what's your experience with Vodafone SIM cards?
I've had no issues on the Vodafone network in Czechia or Netherlands, nor on the KPN network in the Netherlands (via Simyo MVNO); keep in mind I only tested calls and SMS, I don't use mobile data.
Sounds like I should have no big problem then, thanks! If I'm not mistaken Vodafone did issue me a nano-sim in a frame used to place it inside a micro-sim slot... I should thus be good as far as that goes. If I encounter any issues I'll go to one of their stores with the device and ask about it there... albeit no one there ever heard of us, I know since I asked them about Pinephone and Librem / Purism when I paid the bill once and they were like "we have no idea what that is" Tongue
Mobile data is essential for me: I use it whenever I'm out of range from a Wifi connection. Thankfully I've already used Vodafone's mobile data on an USB stick they gave me years ago: It was detected as a modem and worked properly under Linux, both my laptop as well as my desktop! They since replaced it with a tiny router that creates a Wifi network out of the sim card thus I no longer need to plug it in. So if the Pinephone's own modem doesn't complain I'm hopefully all good.
  Pinephone visibly losing power while plugged in Hiraghm 10 9,918 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,063 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 88,638 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 26,867 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,045 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,804 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,438 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,092 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,476 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,918 10-21-2025, 12:12 PM
Last Post: Richy_T
