pinephone drops cellular network
hello,
please excuse my ignorance, i'm not really sure sometimes what are hardware issues and what fall under the software category.
i'm using the latest (updated?) version of manjaro-arm and have noticed that my cellular network has disappeared suddenly. after i restart the network reappears. i'm not sure if this relates to my previous post on 'modem shows no carrier messages' which seemed to have stopped after updating. where can i find some log messages to begin to troubleshoot this issue?
i'm using the koodo/telus network in canada.
thanks.
it happened again this morning in the middle of a call, my cellular network disappeared! after a reboot the network reappears but explorer sms chat now gives me the message, 'device to use sms with:' with no options to choose. my rudimentary understanding tells me the sms software isn't finding the modem!? any help would be appreciated. thanks.
in the interim tried the AT command,
AT+QMBNCFG="list"
from the pine64 info wiki page and nothing was listed!?
Excluding the case that your SIM loses electrical contact maybe due to the  nano-micro SIM adapter or that the SIM has some problem, try again
qdbus --system org.ofono /quectelqmi_0
you will see various operations related to the Network, the SMS etc
for example, unlock the SIM with your pin like this
qdbus --system org.ofono /quectelqmi_0 org.ofono.SimManager.EnterPin pin your_pin
(05-13-2021, 09:02 AM)Rainer Wrote: it happened again this morning in the middle of a call, my cellular network disappeared! after a reboot the network reappears but explorer sms chat now gives me the message, 'device to use sms with:' with no options to choose. my rudimentary understanding tells me the sms software isn't finding the modem!? any help would be appreciated. thanks.
AT+QMBNCFG="list"
I am also experiencing the same problem.
And throughout the week it has become worse.  What started as occasionally losing the phone modem has now become rarely having a mobile connection (with the OS software not even recognizing if there is a cellular modem present).  So, I just stopped using the Pinephone as my daily driver.
I do not believe it is an OS software issue (as I have tried multiple versions of multiple operating systems [most of which use to work fine]); My best (mostly uneducated) guess is that it is a hardware failure (or maybe a firmware failure [that is if the firmware received an updated without me noticing]).
The phone has been known to run hot, and more recently my device has been running hot more often than not.
(05-28-2021, 07:22 PM)LaughWithMeOrAtMe Wrote: I am also experiencing the same problem.
What is your modem firmware version?
If it is outdated, you can try updating it to see if it improves the things.
Same problem for me : https://forum.pine64.org/showthread.php?...1#pid95371
I've change the parameters to reduce the thermal problem from weeks.
I would try to recover the firmware but follow the instructions with precision
https://wiki.pine64.org/wiki/PineModems
First try a freshly installed distribution, for example Manjaro Phosh started acting strangely after two days of continuous use. Install the latest release of the distribution.
Both Linux and modem firmware can be corrupted without an apparent reason.
Of course hardware failures are not impossible but if it happens to many users it is probably something with the software/firmware.
(05-31-2021, 12:30 AM)Gribouille Wrote: Hello,
I've noticed a correlation between "my phone is really hot" and "I can't make outbound calls or text". Did changing the parameters help? And if so, what did you change?
Thank you!
Thank you!
Sorry, I haven't found a solution.
I suppose that the temperature is a parameter. I've reduce the temperature, because my screen is 'dying' : https://forum.pine64.org/showthread.php?tid=13636.
After some 'apt dist-upgrade', the modem disappear in standby mode. If the phone is 'called' (after one night off), the modem is seen, but after some time : no modem, even in the menu 'Parameters'.
With Mobian, since two days, the modem is operational. It's seems that the problem was mainly a software problem, but some time is needed to be sure.
  Pinephone - broken power button rorus 14 23,266 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Pinephone + Keyboard for sale, little use ruemoo 15 10,802 03-05-2026, 10:14 AM
Last Post: diazman39
  PinePhone 16 GB – Free to a Good Home Anna 2 1,356 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 19,239 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,570 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 2,744 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 2,048 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,472 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 3,875 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,832 03-25-2025, 08:51 PM
