Assembling the premium aluminum case
(05-23-2021, 12:22 PM)CounterPillow Wrote:
(05-23-2021, 10:27 AM)jahway603 Wrote: Hi,
I am having trouble with what appears to be a defective premium aluminum case. Once the Rock64 is mounted, the case top does not line up with the "closing" screws. Has anyone else had this issue?
I've had the problem that the case doesn't close due to the board being pulled too low by fully tightened screws, and then not clearing the cutout holes for the HDMI, power and 3.5mm. Try to loosen the screws on that side such that they are only held in but the board has some wiggle room. Then when mounting the top cover, ensure the cutouts for those three ports clear the board correctly. Basically, leave it a bit floppy on one side.
Thank you for this, and I wish that were the same exact problem I was having, but I am having a different issue. Also, the Pine64 support staff is having trouble understanding the problem, even with photos and videos. Their last instructions to me with this defective case would actually snap my Rock64 PCB board, so I refuse to do that and they refuse to send a non-defective case. Since Pine64 support is not being co-operative, I now am asking the community for help. Thanks.
The image of the problem is too large for the forum, but I was able to compress it, so it is attached in the next post.
I was able to compress the image and here is the issue I'm having:
The board not being mounted in the centre is completely fine, it does not interfere with the case closing. Make sure you put the lid the right way around
[Image: thisisfine.jpeg]
Some more things to note:
1. pull out the plastic light guide before trying to insert the rock64
2. pull out the rubber plug before trying to insert the rock64
3. when closing, try not pushing the top straight down, but coming in from the side with the ports and levering it in.
Here's some more pictures. On this, note how the mounting posts are spaced exactly like yours. This isn't the issue.
[Image: IMG_20210526_193219.jpg]
on this one, note how the HDMI and 3.5mm socket are poking through the case. This is still what I suspect your issue is; it'll seem like the board is mounted too far off to one side, but actually, it's that it's not clearing the holes.
[Image: IMG_20210526_193559.jpg]
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(05-26-2021, 11:23 AM)CounterPillow Wrote: The board not being mounted in the centre is completely fine, it does not interfere with the case closing. Make sure you put the lid the right way around
@CounterPillow, appreciated and thanks on your installation description. Thumbs Up.
Nice to see users sharing their experiences here and documenting them too. So important for others coming behind. Well done.
  DeskPi case alternative for ROCK64 v1k699 2 13,412 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,706 05-13-2025, 07:32 AM
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,094 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 28,730 03-04-2022, 06:56 AM
Last Post: killor
Heart Best quick/easy way to control case fan speed? idillicah 4 12,366 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 4,927 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 24,656 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 9,645 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 6,662 02-20-2019, 01:27 AM
Last Post: made2hack
  Raspberry Pi OneNineDesign Case "Mod" MichaelRock 2 6,175 06-20-2018, 04:23 PM
