E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release
I'm trying to resurrect my Pinebook and could use a hand. I've got a black screen and cursor (I skip the login?) so I think something is wrong with Plasma.
I'm starting the fix by trying to run updates (I'm on some 18.* release of Ubuntu under the hood) but I'm getting:
`E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release file.`
It looks like the files I need to point to are here: https://files.kde.org/neon/images/pinebo...eredition/
But when I try to edit my sources.list all I see are the two main Ubuntu ports (bionic and bionic-updates).
Does anyone know where I can find and edit the `http://pinebook.kde.org.uk bionic Release` entry?
try looking int he folder with sources.list for another sources.list file, that should be labeled as specifically kde/neon
what do you edit the pinebook.list to say?
When I add the url to my file it still says there is no release file.
you might try the repos given here in this script https://invent.kde.org/neon/neon/reposit...s.postinst
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 5 15,159 10-25-2026, 04:11 AM
  DietPi OS for Pinebook MichaIng 5 18,026 07-28-2026, 08:02 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 106,540 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 6,235 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,727 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 17,501 04-13-2023, 01:09 PM
  Armbian 22.02 Release Announcement TRS-80 0 4,926 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 8,731 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 11,090 01-04-2022, 09:22 PM
Last Post: irongarment
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,765 01-20-2021, 11:18 AM
