Cant update and upgrade mobian.
Hello , I have problem.
I cant update and upgrade Mobian.
In terminal write
Reading package lists... Error!
E: flAbsPath on /var/lib/dpkg/status failed - realpath (2: No such file or directory)
E: Could not open file  - open (2: No such file or directory)
E: Problem opening
E: The package lists or status file could not be parsed or opened.
is it a fresh install?
(05-04-2021, 02:21 PM)vongillus Wrote: Hello,
No, I install about 1,5 month ago.
You should be able to refresh the apt lists by:
1 Make a backup of your apt lists
sudo cp -R /var/lib/apt/lists/* ~/lists/
2 Remove apt lists
sudo rm -R /var/lib/apt/lists/*
3 Repopulate
sudo apt-get update
Cheers!
(05-04-2021, 09:16 PM)MtnSk8 Wrote: You should be able to refresh the apt lists by:
2 Remove apt lists
3 Repopulate
sudo apt-get update
Cheers!
Thanks.
(05-04-2021, 02:13 PM)mode80 Wrote: Hello , I have problem.
In terminal write
E: Problem opening
Be aware, there was a defect in the boot partition around the time frame you did your installation where you would run out of space and no longer be able to update. Sooner or later you may need to do a fresh installation to fix the problem. Follow the blog. https://blog.mobian-project.org/posts/20...021-03-17/
Now I have a similar problem with the latest Mobian release flashed onto my PinePhone's eMMC
Unable to update "OS Updates":
Prepared update not found: /var/lib/PackageKit/prepared-upgrade
wcdeich4@hotmail.com
Where you able to solve this problem? I am having the same issue.
(12-24-2021, 09:23 PM)wcdeich4@hotmail.com Wrote: Now I have a similar problem with the latest Mobian release flashed onto my PinePhone's eMMC
I see the same notice on occasion, but I think it has to do with the "update Cache",
Sometimes the updates appear before they are released. (?)
I update my daily driver with the Mobian OS every day, I DO see this happen, but it catches up usually within 24 hours.
(as I have multiple Pinephones, I also have one test phone that I run the latest release of Mobian on a sd card, -- first Nightly, now weekly releases.)
Pine would not exist without these great Developers,  but my mission is to prove a GUI User can survive here,
....or at least "Follow along".... with a working phone.  (Talk, Text, data)
It was a quite a challenge back in the Brave Heart days, but it has gotten much easier since then.
...I have had a 'working' Pinephone 99+% of the time since,  and I have never opened a terminal once.
Needing an occasional Restart is not a big deal for me, I hear Android users and iphone users scream when they must do a restart.
but all phone operating systems do need a restart on occasion.
Most of this thread is quite "DATED"  and most of the problems listed here are from the past.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  Mobian MMS/SMS text problem bcnaz 16 35,014 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 974 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 61,069 12-24-2025, 12:11 AM
  No touch KB after update(forky) biketool 4 1,722 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 2,081 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 69,276 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,896 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 325,643 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,598 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,525 06-07-2025, 03:19 PM
