Battery charge threshold
Is there any way to set battery charge threshold to something like 80% or so?
For example, ThinkPads have such option to set battery charge threshold:
echo 60 > /sys/devices/platform/smapi/BAT0/stop_charge_thresh
I did not see similar options for the Pinebook Pro, so I tried to search in the arch/arm64/boot/dts/rockchip/rk3399-pinebook-pro.dts kernel file, but the only thing close to a battery charge limit I've found was this:
charge-full-design-microamp-hours = <9800000>;
I guess I could lower it and probably achieve such effect, but maybe there is a better solution than lying to the system about the actual battery design full charge?
I'm interested in this too. I had previously looked into it and was convinced it's a hardware feature that is unusual. Seems silly when it's well known that batteries live longer with charge limits and there are phone apps that do it.
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,238 03-15-2025, 01:47 AM
Last Post: frank_philip
  Improved battery life with TLP daemon Surehand53 0 3,489 12-30-2024, 07:46 AM
Last Post: Surehand53
  Battery gauge issue (mainline kernel) lfourquaux 4 11,361 05-22-2021, 02:43 PM
Last Post: jiyong
  eMMC frequently not found by Linux kernel (especially on low battery) v-man 14 30,696 05-14-2021, 01:18 PM
Last Post: djhnsn
Question Manjaro arm + sway - battery indicator broken mfashby 6 13,855 02-20-2021, 04:07 AM
Last Post: mfashby
  Possible battery and performance improvement xehartnort 4 9,985 11-09-2020, 12:26 AM
Last Post: rimaille
  Manjaro - No battery info after plugged in AlecM 4 10,067 09-16-2020, 08:34 PM
Last Post: zer0sig
  get battery status on the command line rossk 2 10,266 04-04-2020, 09:25 PM
Last Post: rossk
  i3status issues reading battery status dummy 9 21,488 01-31-2020, 08:27 AM
Last Post: C_Elegans
