DIY case backs, screw attachment
Since we are buying an experimental phone and with the pogo pins the assumption is we will be using alternate DIY casebacks; what safe options do we have for attaching a 3D printed caseback with screws?
Specifically I would prefer a hardware model with extra threaded screw holes for say M1 machine screws but I doubt we can have that before the next hardware rev betas in 3-4 years. In the absence of an updated hardware design is it possible, safe, and wise to use some of the screw holes that hold the interior cover to the frame?  If so which holes, what size screws, and how deep can the screws safely enter the frame?
As a side question is there a PCB with a kapton ribbon and breakout for the pogo pins now?  it would make designing DIY casebacks easier if I could just use adhesive to attach the pogo interface and attach the back with screws.
For those who are not already 3D printing the hot plastic squirting types can make a reasonably strong plane in a few mm but the sidewalls will never be strong enough to 'snap' on as the stock caseback does, hence the screw attachment thoughts.
See https://wiki.pine64.org/wiki/PinePhone_Modding - there's a pogo breakout PCB that could be used as the basis for a flexi, and uses a couple of the screws to attach. I think you could use any/all of the screws to attach a back, but we don't have the necessary dimensions or models - they have been asked for, but so far all we have is the back cover so measurement would be needed. I guess I should stick the phone on a flatbed scanner...
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 3,511 04-30-2022, 08:18 PM
Last Post: TRS-80
  Case hardware request/idea HobanWashburn 5 9,573 09-15-2021, 04:02 AM
  Battery phone case expected? Cpm 1 4,175 08-10-2021, 03:29 PM
Last Post: 33YN2
  Nintendo 3DS case Fritz Fischer 1 4,102 08-08-2021, 11:39 PM
  Pinephone gamers case (like ODROID-GO) mitcoes 1 3,915 05-11-2021, 07:15 AM
Last Post: gamerminstrel
  Minor design fault in case SocialNetworkingWasAMistake 4 8,359 12-15-2020, 01:08 PM
Last Post: SocialNetworkingWasAMistake
  Remove striped screw pizzalovingnerd 18 29,883 12-08-2020, 02:22 PM
  Case backing with no logo Phillip Bell 6 12,518 11-08-2020, 11:00 AM
Last Post: plarkinjr
  3D model of phone or case hnaguski 2 7,166 11-30-2019, 06:05 PM
Last Post: nas
