03-27-2021, 07:48 AM
can someone tell me how to unintall and reinstall megapixels in terminal? using mobian
megapixels
03-27-2021, 11:46 AM
On my Mobian PinePhone, I see it listed as installed in the Software app, with a button to remove it. I haven't tried. Have you tried that and it fails in some way? I haven't tried installing it using the Software app, but it is listed as available. So, you should use the Software app to uninstall and reinstall it.
03-27-2021, 04:39 PM
In terminal :
(remove app + config with --purge) sudo apt remove --purge megapixels (remove leftover dependencies) sudo apt autoremove (reinstall) sudo apt install megapixels or a oneliner just to remove and reinstall megapixels (you keep config and dependencies are not removed nor reinstalled - ie: they stay in place) sudo apt-get -y remove megapixels && sudo apt-get -y install megapixels
03-28-2021, 08:52 AM
if your a tech moron like myself and you decide to uninstall megapixels to see if a reinstall will get it working, dont do it. if you do you will need the excellent advise given above by bitsandnumbers. thanks by the way. i dont know if its just me or all mobian users, but the camera on my phone has never worked. when i loaded megapixels i got a blank screen and now it wont even open. is it just to early for the camera to work or is there something i can do to get it working?
03-28-2021, 11:31 AM
I've got not advice to help you make the camera to work (though I know I've seen your issue discussed before), but the camera is actually supposed to work - not *very* well right now, but it's getting there and post processed pictures are pretty decent.
03-28-2021, 02:09 PM
(03-28-2021, 08:52 AM)rvh Wrote: ... In general it is working as well as can be expected at the moment for a basic sensor. Are you sure you haven't got it disabled on the DIP switches? Otherwise check what you have in the systemlog: I have a 5.11 kernel but you should have something like Code: [ 16.973553] videodev: Linux video capture interface: v2.00Last, check this thread for more on the travails of megapixels and a current defect in the postprocessing.
03-28-2021, 03:25 PM
Ok only i dont know how to get the code or how to place it here. P.S. thanks for your time.
03-29-2021, 02:23 AM
Do you get a preview in megapixels when you start it? When you switch between front and back camera in the app, does that work?
Come have a chat in the Pine IRC channel >>
03-29-2021, 07:09 PM
right now, the camera wont even open.
04-01-2021, 06:39 AM
i reinstalled megapixels and now have the back facing camera working only the pics are just vertical lines. the front facing camera wont open.
| Megapixels wont start | Barugon | 3 | 6,036 |
07-01-2021, 07:15 PM Last Post: nelstomlinson |
