Mobian Constant Vibration
I know this has been addressed on other threads with different versions of Pine Pine but was wondering about a solution.  I have read other threads where it stated about pinching wires but this phone is totally enclosed with no exposed wiring.  I had placed a Straight Talk SIM in the phone but didn't seem compatible so I removed it.  Not long after that, I started noticing the constant vibration.  As it powers on, it will start vibrating even after updating the software, removing and reinstalling the battery, etc.  On a side note, I did get the Red Pocket service to work very well using a GSMA SIM from the SIM kit on eBay.
Is the phone trying to give me a notification or is it a malfunction?  Any suggestions on a remedy?
Seems like malfunction to me. I think someone posted a photo of the pinched wires to the vibrate motor and they wouldn't have been visible until the midframe plastic was removed.
Well, I solved the problem.  In the process of taking the phone apart, I left it plugged in while it was constantly vibrating.  At the point of removing all of the small screws, it stopped vibrating while it was still turned on.  It continued to stay off so I slowly replaced screws until it started back up again.  I was able to replace all but one screw in the back and keep it from vibrating.  I did not have to cut any wires or any other modification but the screw.  As I tried to replace the last screw, I just started the screw and it would start vibrating again so I'm leaving that one out.  So far, so good and its working normally.....knock on wood.  The screw I left out was the one up from the bottom right corner as you look at it from the opened back. I attached a photo of the screw I left out.
(03-26-2021, 09:55 AM)tumblingdog Wrote: Well, I solved the problem.  In the process of taking the phone apart, I left it plugged in while it was constantly vibrating.  At the point of removing all of the small screws, it stopped vibrating while it was still turned on.  It continued to stay off so I slowly replaced screws until it started back up again.  I was able to replace all but one screw in the back and keep it from vibrating.  I did not have to cut any wires or any other modification but the screw.  As I tried to replace the last screw, I just started the screw and it would start vibrating again so I'm leaving that one out.  So far, so good and its working normally.....knock on wood.  The screw I left out was the one up from the bottom right corner as you look at it from the opened back.  I attached a photo of the screw I left out.
Looks like the screw hole close to the Vibrator wiring. My guess the screw may shot one vibrator contact point and cause the vibration.
Thanks, I have a similar issue. Removing the screw made the constant vibrating stop but only for a few minutes. I tried to remove all the screws while keeping it on and vibrating stopped periodically but then started again and now it it back to constantly vibrating. Any other ideas for how to stop the constant vibrating?
  activate vibration motor in bash script? vusra 0 890 07-18-2026, 03:47 AM
Last Post: vusra
  Mobian MMS/SMS text problem bcnaz 16 40,059 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,709 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,610 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,961 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
