How to clear recent call list?
I have a bunch of test calls in my recent call list that I'd really like to clear out. How to do this? Is there a file somewhere that can be deleted or edited?
(03-25-2021, 02:13 PM)Zebulon Walton Wrote: I have a bunch of test calls in my recent call list that I'd really like to clear out. How to do this? Is there a file somewhere that can be deleted or edited?
If you delete all 3 files in ~/.local/share/calls will remove your call history. (Or alternatively, as I do, backup and restore that directory each time I do a new install to preserve my call history.)
Thanks, deleting those files and rebooting cleared out the recent calls list.
  Modem wakes for incoming call, but too slow to answer the call dchang0 8 6,864 12-01-2024, 07:54 PM
Last Post: dchang0
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,966 08-05-2024, 06:12 AM
Last Post: baptx
  Quick question abtut sources.list jojuma 1 3,035 06-17-2024, 04:46 AM
Last Post: zetabeta
  Most recent Mobian image or installer image known to work? DrPlamsa 13 17,128 02-26-2023, 11:47 PM
Last Post: SukiiPooru
  Recent install, no wifi user641 3 5,218 01-12-2023, 03:06 PM
Last Post: user641
  [SOLVED] Lost Internet connectivity after recent update drh 3 5,772 09-11-2022, 09:24 PM
Last Post: Katsujinken
  Pinephone incoming call / SMS notification no ringing / notification volume dcinoz 3 7,684 06-02-2022, 07:16 AM
Last Post: arkadione
  Vibration motor buzzes uncontrollably with call waiting Zebulon Walton 2 4,611 05-28-2022, 07:32 PM
  Calls : two rings and call cut and restore. Gribouille 0 2,300 01-14-2022, 07:40 AM
Last Post: Gribouille
  GDM3 Receiving call on login screen d-.-b 4 8,740 10-07-2021, 06:59 PM
Last Post: d-.-b
