Application list PMOS-Phosh
[Updated November 13, 2021]
Alpine / Postmarket has over 21K packages for routers, servers, appliances and desktop.  And multiple phone interfaces.  So what are the current best practice apps?  It can take some effort to figure that out.  So a list!  Obviously it is incomplete but a place to start.  Will try to keep this top post edited as suggestions come in and the state of play changes rapidly.  Would also be willing to maintain a similar list for Plasma if enough contributions come in.
Assuming you are running Edge since things are still moving pretty quick.
Browser
  • Firefox-esr is the best supported option, be sure mobile-config-firefox is also installed to make it usable on a phone. The mainstream firefox is also available and some people report it works with the mobile config as well.
  • Chromium now works out of the box.  Always good to have a second browser for balky sites.
Communications
  • The base Chatty does XMPP inline with SMS so that is covered.  MMS and SIP support are now experimental.
  • Dino gives you XMPP support including conferences.
  • Telegram is in the repos.
  • Fractal gives you riot.im / Element / Matrix access.
  • Hexchat is in the repos, just don't expect much on a phone screen.  (Any other IRC?)
  • No Discord or Signal yet.
Email
  • Don't know.  Evolution is in the repo but not terribly useful on a phone.
Camera
  • Megapixels is the only game in town for PinePhone and is currently fairly good for still pictures.  It even recognizes QR codes.  No effort at video support yet.
  • Cheese is good if your camera is supported by the usual GNOME Gstreamer plumbing.  Pinephone isn't.
2FA Authentication
  • Numberstation is now in the repos and seems to work like it should.
Navigation
  • Gnome-maps works if you have constantly available data.
  • Pure-maps is supposed to be able to work if you jump through enough hoops for API keys and are willing to drag in some Qt dependencies.
  • If you need offline navigation and do not want to struggle too much, see the anbox/waydroid notes below about OsmAnd~.
Document / Ebook viewer
  • Evince seems the consensus choice.
Image Viewer
  • eog (Eye of Gnome) is the default even if it isn't well optimized for mobile.  Ideas?
File Manager
  • Portfolio is working well now and is optimized for a phone display.
  • Nemo seems to be installed by default, but it is clumsy on a phone display.
Text editor
  • Mousepad looks pretty good to edit, file dialogs are a bit whack on a phone.
  • Gedit is often installed by default but the UI tends to overflow the screen.  No perfect choice yet.
Music player
  • Lollypop is the current best choice.  It supports pausing suspend.  Still a bit buggy.
  • Gnome-podcasts is also a recommended choice, serving a different need.
Video player
  • Vlc-qt is probably the best option, same as everywhere else. Not really mobile optimized and frame rate stinks, but it is the only real choice.
  • Mpv is out, no UI.
  • Mplayer also has no UI.
Other multimedia
  • Sound-recorder
Utilities
Things you might want that don't fit a category above.
  • gnome-calculator (only one that actually works on a phone)
  • gnome-clocks (alarms might not go off from suspend, but it is supposed to work now.  Don't overly rely on it yet!)
  • gnome-calendar isn't well optimized (adjust scaling!) but it works.
  • gnome-disk-utility
  • gnome-usage
  • powersupply
  • dconf-editor
Anbox
Anbox works well enough to be useful, but it has glaring problems.  The onscreen keyboard can't shift and it won't see a BT keyboard at all.  Sometimes it won't see the onscreen keyboard either. Many apps, especially involving sensors, simply won't run at all.  The useless extra bar with a redundant close button is annoying but livable.  It can fill two important holes in application coverage though.
2FA
  • FreeOTP runs and produces the same results as a real Android phone.  FreeOTP+ and the other probably work as well.  No camera of course so no QR codes, either import existing ones from another device or try to put in the long string correctly.  With a dodgy keyboard.
Navigation
  • OsmAnd~ runs and even gets a location lock and downloaded my home State's maps for offline use.  The keyboard problems would be an issue eventually, but it is usable now.
Waydroid (New for November update)
Waydroid is still in rapid development but already generally performs better than anbox.  The onscreen Android keyboard works, My BT keyboard double enters every keystroke and does something whack with a pointer that also renders it unusable.  But network now works and the screen is a lot more responsive.  No GPS yet, but OSMAND~ does install and you can manually look at the map.  As of now though, waydroid is just for playing with since it devours your battery if a waydroid session is enabled. The phone simply will not sleep, the screen keeps turning itself back on.
Thank you for this cool list - highly appreciated!
I was wondering if there is VOIP/SIP app you could recommend (such as linphone) as well as a mumble client? I was thinking about using such apps via anbox, however, I wonder if (a) audio would be routed correctly and (b) how the impact on battery life would be in case of the SIP app.
(03-17-2021, 12:33 AM)jmorris Wrote: The base Chatty does XMPP inline with SMS so that is covered.
But no multiuser chats. (MUC)
I have read that Dino has recent developments using libhandy to fit to the mobile screens.
Does PMOS include already that version of Dino?
Didn't even know about that one.  Yes it is in the repos and yes it looks like good on a phone.  Will be adding that one.  Thanks!
(03-18-2021, 06:13 PM)kuleszdl Wrote: Thank you for this cool list - highly appreciated!
SIP is a battery killer, even on Android.  Means the network stays alive constantly, CPU stays awake, etc.  The modem can deal with SMS and Voice so the main SoC can stay asleep until something happens, not so with SIP.  And Anbox probably won't get it done quite yet anyway, keyboard input is still spotty at best.
Anbox is so close to a breakthrough in usability.  A few fixes get done and the number of apps that cross to "usable" will explode.
@jmorris Not sure if SIP is really *such* a battery killer. The battery of a typical Android device with a Qualcomm chip (big-little architecture) lasts for about 3-5 days on SIP with receiving calls working perfectly. Sure, it has to keep the wifi on and maybe also one cpu core at the lowest frequency. Yet, it IMHO doesn't have to be such a terrible battery eater - but this might be different with the pinephone's hardware of course.
Leaving the battery eater aspect aside - is there any useable native app that works as a sip phone? Linphone maybe?
(03-17-2021, 12:33 AM)jmorris Wrote: Alpine / Postmarket has over 18K packages for routers, servers, appliances and desktop.  And multiple phone interfaces.  So what are the current best practice apps?  It can take some effort to figure that out.  So a list!  Obviously it is incomplete but a place to start.  Will try to keep this top post edited as suggestions come in and the state of play changes rapidly.  Would also be willing to maintain a similar list for Plasma if enough contributions come in.
Browser
  • Chromium can be made to work with patches found elsewhere in this forum (might be upstream by now, try it).  Always good to have a second browser for balky sites.
Communications
Email
  • Don't know.
Camera
  • Megapixels is the only game in town for PinePhone and is currently unreliable at best.
2FA Authentication
  • Gnome-authenticator is currently "mostly broken."  With patching I got the add account dialog to appear but it segfaults on any activity.
  • See anbox below for a solution.
Navigation
  • If you need offline navigation and do not want to struggle too much, see the anbox notes below about OsmAnd~.
Image Viewer
File Manager
Text editor
Music player
Jack switching isn't working on PinePhone yet so you will need alsamixer, etc. to enable the headphones and mute the speaker.
Video player
  • Vlc-qt is probably the best option, same as everywhere else. Not really mobile optimized but it is the only real choice.
Think i'm in the right thread.  I am running AlpineOS w. Phosh.
Other multimedia
  • Sound-recorder
Utilities
  • gnome-clocks (alarms might not go off from suspend!)
  • gnome-usage
  • powersupply
  • dconf-editor
Anbox
2FA
Navigation
I think this is the right thread for me.  I am running pmOS Alpine / Phosh.
Anyone have any idea what the "adaptive apps" button is for. I'm at a loss.
(03-17-2021, 12:33 AM)jmorris Wrote: [Updated November 13, 2021]
I confirm, enabled waydroid session will empty your battery pretty fast. At the moment it should be switched on and off manually.
  [Phosh] : Nheko and gnome-keyring freelectro 1 2,702 12-17-2024, 04:46 PM
Last Post: zeb11
  Fresh install pmos+phosh does not boot user641 1 3,700 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 13,040 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,518 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 8,723 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 14,757 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 3,606 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 6,296 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 14,653 02-03-2022, 09:14 PM
Last Post: parry
  Caller, chat and contact list no longer running chadwick 2 4,274 10-08-2021, 05:11 PM
Last Post: mark1250
