Headphone jack issues Manjaro
Anyone know how to get sound to output from headphone jack rather then through HDMI. I messed with the alsamixer and just couldn't figure it out. Anyone have a solution?
I figured it out. In terminal type:
sudo alsamixer
Select rockchip sound device
Tap right key all the way till you see left headphone and right headphone. There will be a square above with label MM. Click on it with mouse and u should see 00. Do that for each of them. Then scroll back right and raise DAC to 100%. Then exit terminal. Select headphone jack in audio volume controller and everything should work.
I did notice that after a reboot, alsamixer configuration gets reset. Is there a way to save the alsamixer configuration after alteration?
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 1,270 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,972 02-17-2022, 12:10 PM
Last Post: flounder
  CPU Fan Won’t Turn On in Manjaro publiclewdness 0 2,403 12-31-2021, 12:51 AM
Last Post: publiclewdness
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 5,265 09-11-2021, 08:58 PM
Last Post: t4_4t
  OMV to Kodi Streaming Issues cogito808 12 28,254 05-25-2021, 08:30 AM
Last Post: helpmerock
Thumbs Up First Manjaro Mainline build! Luke 10 26,469 10-20-2020, 04:29 AM
Last Post: vfr400racer
  Wifi on Manjaro User 19517 0 3,397 09-14-2020, 06:53 PM
Last Post: User 19517
  No audio output with Manjaro Arm 20.04 Faradn 2 7,469 08-02-2020, 09:48 AM
Last Post: new-rockpro-user
  RockPro64 Linux Manjaro HDMI 4K mkne 12 25,414 05-03-2020, 07:23 AM
Last Post: PakoSt
  RockPro64 - Armbian no sound from jack Pineapple 0 3,409 09-16-2019, 08:27 AM
Last Post: Pineapple
