PBP USB-C Docking Deck HDMI 4k upto 60fps possible?
Hi I am starting to use the USB-C deck to connect to my 4K monitor.
The description for the item on Pine store is 4k/P30 (means 30 fps?), and that's what I got when I am using it. But on the other hand the USB-C to HDMI converter I had is allow me to select 4K at 60 fps on the display setting, where the PBP deck only allow the 4k 30 fps selection.
Is it possible the HDMI cable I am using the bottlenect, there isn't any meanful lable I can tell. Happy to buy a new one if it might be the issue? But on the other hand, it might be a hardware limitation due to the deck need provide USB3 and HDMI outputs at the same time from a single USB-C connected to the PBP for input?
Any USB dock that supplies USB3, (even if it's internal to Ethernet or SD Card reader), can't supply 4K @ 60fps.
Simple bandwidth issue. It needs all 4 lanes for 4K @ 60fps, but then their are no lanes for USB 3;
https://wiki.pine64.org/wiki/Pinebook_Pro#Video_out
Arwen Evenstar
Princess of Rivendale
(02-27-2021, 10:56 AM)Arwen Wrote: Any USB dock that supplies USB3, (even if it's internal to Ethernet or SD Card reader), can't supply 4K @ 60fps.
Thanks Arwen, then no need for new HDMI cable Big Grin
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 9,851 01-02-2026, 04:26 AM
Last Post: stu73
  HDMI and PBP USB C port IMSAI8080 0 2,769 09-26-2022, 09:17 AM
Last Post: IMSAI8080
  PBP (PPP) docking deck detailed spec Rosbeefandino 6 8,828 09-14-2022, 10:59 PM
Last Post: dachalife
  PBP (PPP) docking deck : no hdmi sound Rosbeefandino 0 2,508 07-24-2022, 06:19 PM
Last Post: Rosbeefandino
Question PINEBOOK Pro USB-C Docking Deck issues pawzy 3 9,010 06-19-2022, 09:47 AM
  Pinebook Pro Docking Deck Seems to be DOA Inig0M0nt0ya 1 4,438 02-19-2022, 10:22 PM
Last Post: angeloweb
  Ethernet issue on USB-C Docking Deck Nongorre 2 5,692 02-19-2022, 10:18 PM
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 4,642 06-16-2021, 07:49 PM
Last Post: Kuawi
  Docking Deck shipping? tkudog 3 8,053 05-18-2021, 07:29 PM
Question Disassembling PineBook Pro Docking Deck (due to disappeared microSD card) gritibaenz 4 8,671 04-02-2021, 06:45 PM
Last Post: tkudog
