Plasma Mobile airplane / aeroplane mode / mobile off
Evening here and I normally put my phone in airplane / aeroplane mode i.e. would look for a toggle to disable modem / mobile data / wifi / BT if any are on.
I could find no such thing on Manjaro Plasma Mobile 20210221.
I panicked when I went to settings and saw internet had a tick - even though the Mobile Data icon in the top bar settings is not on....does that toggle not work?
So surprise, no mobile modem off either. Or could the Mobile Data icon actually toggle mobile / mobile data on / off?
I have my mobile modem on with data off due to cost.
I did not find a quick way to turn data on / off via ofono command.
Neither a way to turn mobile modem on / off via ofono.
I did a brutal
sudo pkill ofonod
and that worked - no more mobile icon in the top bar.
I lodged a bug report at https://gitlab.manjaro.org/manjaro-arm/i.../issues/69
I appreciate any comments from anyone with more Plasma Mobile experience. Mobian has quirks including with their Airplane toggle (still not fixed....) but you can turn mobile on / off, data on / off.
I assume this bug report covers the mobile data icon toggle:
https://gitlab.manjaro.org/manjaro-arm/i...-/issues/9
I hoped the ofonoctl command as per https://git.sr.ht/~martijnbraam/ofonoctl
sudo ofonoctl offline
would work but it doesn't.
Same with modem power off command
sudo ofonoctl poweroff
it doesn't do anything.
and service start / stop / restart doesn't work either for ofonod, I don't know how to start / stop it properly.
Worked it out:
Stop ofono:
sudo systemctl stop ofono
Start ofono:
sudo systemctl start ofono
After ofono start (if turned off before), modem power is off and offline, so you need to do:
ofonoctl poweron && ofonoctl online
You can check the status with:
ofonoctl list
and for WWAN:
ofonoctl wan
Note that
ip a
and
ip route
do not show any WWAN routes so perhaps mobile data is actually off?
(02-22-2021, 05:54 AM)dcinoz Wrote: Hi,
I did a brutal
sudo pkill ofonod
I just installed the same image, and see a "Mobile Data" button in the action center at upper right corner. Enable/Disable there
Mobile data doesn't actually turn it on / off it is always on, apparently, but ofonoctl doesn't get an ip address and set up a wwan route. If you do it manually and toggle mobile data 'off' it doesn't do anything. Missing scripts somewhere to do that?
Part of my post was about mobile being on without data and switching mobile off. There is no toggle option in the current settings to 'just' turn mobile on / off.
Script to turn modem on / off and enable / disable data is available here:
https://forum.pine64.org/showthread.php?...8#pid90498
  Wi-Fi Issues (Plasma and Lomiri) PineSupporter 11 21,707 02-20-2026, 12:16 PM
Last Post: krissprat73
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 3,940 07-03-2024, 08:38 PM
  what is wrong with KDE plasma beta15 RC4? Uturn 8 10,142 10-02-2023, 05:07 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 16,133 03-02-2023, 07:25 PM
  Flight mode turns off wifi but not the modem (cellular) jojuma 2 4,347 02-28-2023, 01:58 PM
Last Post: calinb
  gnome-mobile dev Uturn 1 3,315 02-22-2023, 03:37 AM
Last Post: acrux
  Manjaro plasma-mobile Beta 13 Uturn 13 16,680 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 4,702 11-22-2022, 05:00 PM
Last Post: Chief
  Disabling screen timeout for plasma mobile rp3 7 16,198 09-05-2022, 03:50 PM
Last Post: christev1
  VPN on Plasma Hobgoblin 1 3,322 08-29-2022, 03:14 AM
Last Post: saddamus
