GPS is broken! Change wiki and page! And where is the antenna ?
Exclamation
After seeing other posts I can tell that the gps does not work. You should update the wiki, product page and shop page and change the gps status as 'broken' or 'partial working', to notify the clients.
I think its because of a bad gps antenna, can you tell me where is it ? and can i connect an external antenna ?
Hardware worked fine with my Brave Heart last time I tried it. Performance was similar to other smartphones when using the AGPS data loader, but first fix was unreliable without AGPS. This is also true of most smartphones if you can force them not to use AGPS - a decent GPS antenna is even bigger than the headphone sockets many manufacturers think take up too much room. For most people the problem is that AGPS isn't used by any of the distros yet so it's not easy to use, much like the current state of MMS support. The mobian wiki has a fair amount of detail: https://wiki.mobian-project.org/doku.php?id=location
The number of people with a hardware fault seems to be small so far - at least I only remember one or two. That's not great but not (yet) an indicator of a wider problem.
You can find the antenna via the schematic and the component layout docs - IIRC it's the printed antenna on the top corner by the camera bump, with spring terminal connections on the main board. I don't think it has a connector that you could easily attach a different antenna to.
I hadn't realised this wasn't in the Pine64 wiki - I'll see about adding something. You should be able to edit the wiki using the same credentials as the forum, although I gather this broke for a bit so you may need to contact an admin if it doesn't work for you.
(02-03-2021, 07:08 AM)wibble Wrote: Hardware...
Thanks for the info.
1. One dont buy a experimental phone, suffer to instal experimental OS, waits 2 month for the delivery, to give your geolocation to google or chinese or another big tech ! I can buy a 70$ android phone for that.
2. agps is eventually used to reduce the fixing time from 10 min to 2 min, now from infinite to... idk.
3. I hope for pine that my case is rare but ive seen many posts about this, and a lot of people just havent tested. I'll see if the cable is disconnected.
1. I did my research before buying and knew software (and possibly hardware) was a work in progress. Having previous experience with the OpenMoko might have given me a better idea of what to expect. The AGPS data is fetched via a web request which you can run through a proxy or VPN if you don't want the remote server to be able to use GeoIP or similar. It doesn't need to know where you are because it's just providing the almanac and ephemeris data that the GPS sats broadcast slowly, and that's needed to get the first fix. Of course if you've got a SIM in any phone the provider has a pretty good idea of your location.
2. ??? In my experience it's comparable to GPS on other smartphones - they're almost useless without AGPS too, but similarly quick with it.
3. I don't think there is a cable to become disconnected. There are spring terminals that are meant to touch conductive paint.
Exclamation
I had a look at the GPS antenna, at first i was shocked cos its a sticker! Then I noticed that also many other smartphones has a similar antenna.
Could the problem be that the antenna is bent around the edge ???  Huh I dont think that that kind of antennas are supposed to be bent.
  Jumpdrive broken? eMMc broken Uturn 5 7,531 04-21-2023, 12:37 AM
Last Post: Uturn
  UI crashes after unplugging USB device, seen on multiple OSes; is my hardware broken? slondr 1 3,135 11-05-2022, 11:31 AM
Last Post: slondr
  list of linux native apps/softwares for pinephone on the wiki alexandre 7 17,455 10-26-2021, 11:56 PM
Last Post: bcnaz
  my broken pinephone, possible sale zetabeta 4 7,741 09-28-2021, 11:09 AM
Last Post: fervi
  PmOS Phosh: set compose and change layout stozi 3 5,936 09-24-2021, 07:41 AM
Last Post: ryo
  How to use Pinephone as wifi antenna for Pinebook Pro stozi 3 5,880 08-26-2021, 05:05 AM
Last Post: wibble
Photo Page allocation failure on KDE Community edition -"0 pages hwpoisoned" countcitrus 1 3,755 02-20-2021, 06:16 PM
  How to reinstall a broken OS on Pinephone's internal storage? danimations 1 5,421 01-24-2021, 10:14 PM
Last Post: danimations
  Contribute tu Pine64 wiki p1trson 3 6,439 11-24-2020, 05:12 AM
Last Post: evilbunny
  suggestion the broken screen issues dallytaur 0 2,749 11-19-2020, 10:27 PM
Last Post: dallytaur
