Virtualizing Pinephone Operating Systems?
Hello all, first post after a long lurk!
I am planning to preorder a pinephone, and in preparation I would like to be able to explore the OS options so I can quickly settle on a daily driver. I am hoping to fully replace my android and this is basically the last step in my de-googling process. I do need some functionality for work however, so again, I would like to explore the available operating systems while I wait for shipping to begin.
Is anyone aware of a method of running any of the supported OSs in a virtual machine such as KVM? I tried to get iso files but could only get installer tools and .img files for the ones I was most interested in. If anyone has any insight I would very much appreciate it!
If you're on Gnome (or some other Gnome-based shell like Cinnamon or Unity), you can just download the source code, compile, and run as instructed in the README file.
You can run Phosh inside of Gnome/Cinnamon/Unity/whatever using:
SKIP_GNOME_SESSION=1 ../phoc/_build/run -E '_build/run -U' -C ./data/phoc.ini
The application menu will show apps you have on your own PC, but some of those that support libhandy will run inside of it and kind of behave like their mobile versions.
Apps without this support will simply open in a separate window like usual.
The reason is simply because Phosh is really just a Gnome shell for small touch displays.
Everything beyond that is literally the same as on a PC with a Linux distro running Gnome DE.
Edit:
In case somebody starts attacking me for helping you like last time, I'll add this page as an alternative option:
https://developer.puri.sm/Librem5/Develo.../qemu.html
However, I didn't test this method.
母語は日本語ですが、英語も喋れます(ry
If you want to sandbox it, maybe try with something like QEMU and an image of your choice? I know someone who have used this method to successfully do it in order to test a keyboard layout for squeekboard
  Pinephone software Csanderson0313 3 1,412 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 84,619 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 24,709 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 8,228 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 8,216 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,524 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,986 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 2,590 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,059 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 8,110 10-21-2025, 12:12 PM
Last Post: Richy_T
