Using sway along phosh
As a sway user on desktop, I've been trying to use it on my pinephone. One of the shortcomings is that on mobian, most of the phone related functions are (well) integrated into phosh and I didn't want to loose that.
Sway use on the pinephone is mostly interesting in docked mode or when a keyboard is plugged in ...
I've identified 3 ways to achieve sway integration
 1 - run sway on a tty
 2 - run sway inside phosh
 3 - replace phoc with sway as phosh compositor
1 is trivial, you switch to a tty (Ctrl+Alt+F1 on the keyboard), log in and launch sway. It works well but is not really integrated. For instance, when you receive a call you need to switch to phosh terminal, and so I quickly abandoned this solution
3 seems to need some work and might not be feasible due to the way phoc and phosh seems to be tight together through D-Bus things ...
2 has always had my preference, and I didn't know why it never worked when I tried it, since as sway can be used as a wayland client, it should be as easy as typing sway in a terminal. Today I gave it another try and figured out what was wrong. Before launching phoc it restricts WLR_BACKENDS to drm and libinput. And sway was using this variable. So to run sway this way all you have to do is type WLR_BACKENDS=wayland sway ... and it magically works.
Then to use it fullscreen I associated toggle-fullscreen command to Alt+F11
There are still some issues, one is that sway don't get the good keys from the squeekboard that runs in phosh. But this way, you can keep a full desktop in a corner, pop it up when connected to a screen or just to a keyboard, and I find this quite interesting ...
Hope it will be of some help to some of you
Regards,
FdL
phosh can also be run from sway or any wm/compositor ... and its very neat as convergent desktop
I just found your thread while looking for something else, but I am using the same on Droidian with a keyboard-slider phone, made a quick video to demonstrate it: https://youtu.be/WkxzsoP8BvI?t=154
However, have you found a way to make apps open from Sway open in Sway? This only works for a fraction of apps, most of them will still open as new Phosh windows instead of within Sway, or won't open at all. Still really useful for TUI apps, but I would like to be able to show 100% of apps as Sway windows.
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,689 01-15-2025, 08:08 PM
  Auto start application on Phosh login Zebulon Walton 8 13,513 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 5,486 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 26,561 10-14-2022, 05:38 PM
Last Post: Krafter
Exclamation Impossible to minimize a window with Phosh anonymous 7 10,475 08-18-2022, 01:53 PM
Last Post: dante404
  Phosh 0.20 beta on mobian Anthony1224 1 3,974 06-11-2022, 06:29 AM
  Transparent Phosh App Grid? arno_nuehm 1 3,765 03-15-2022, 06:00 AM
Last Post: dante404
  Phosh modem on/off effectiveness? Zebulon Walton 0 2,457 01-24-2022, 09:21 AM
  Updating Phosh from Gitlab ragreenburg 2 5,071 10-07-2021, 08:35 AM
Last Post: ragreenburg
  Seems like Phosh is in downgrade mode... ryo 17 31,242 06-01-2021, 06:22 PM
Last Post: ryo
