screen goes blank when I insert pinephone dock, or usb-a to usb-c adaptor
Hi, does anyone know a fix for this?
I tried plugging in my pinephone dock (with nothing in it) to my pmos ce pinephone, running mobian, and the screen goes blank. If I unplug it, the screen comes back on again.
I have never used the dock for anything previously, or changed any settings in regard to it.
I was just going to plug a usb memory stick into the dock to transfer files to and from the phone, using a file manager.
The same thing happens if I plug a memory stick into a usb-a to usb-c adaptor, then plug it into the pinephone. (the activity light on the pendrive flashes for a second or two, however)
Regards everyone!
I have a couple usb-C devices myself, and behavior is a little quirky. For a couple of them, the display turns black like you described. However, if I plug the USB-C hub in question into a charger, the display turns back on. I think it might be some weird quirk or bug concerning power draw on external devices.
You have to turn up the screen brightness before plugging in a device that drains much power.
Thank you both so much for the feedback, you were both exactly right.
When I first plug in power to my pinephone dock before inserting it into the pinephone, the screen stays on as normal, -all good!
Also, (and I probably never would have found this myself!) if I increase the brightness of the pinephone to at least 30% on the slider, the screen can still be seen to be on, though it does dim a bit.
I suppose this is actually a small bug?
I appreciate both your time in replying!
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,541 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,711 12-24-2025, 12:11 AM
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,333 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 11,725 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,362 11-04-2025, 04:13 AM
Last Post: JChdeL
  cryptocurrency on mobian/pinephone biketool 33 74,611 10-08-2025, 06:21 AM
  New Install, apps start but don't show up on screen?! RT3 2 3,556 07-18-2025, 07:56 PM
  Axolotl on PinePhone / Mobian arno_nuehm 223 352,000 06-25-2025, 01:19 PM
Last Post: anonymous
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
