Debian Bullseye installation
Hello, extremely new to Linux in general, had lots of help in figuring things out with my PBP. Wanting to try out Debian on my SD card and ran into some troubles. Got the installer script completed, but when I load up again I get a black terminal screen, with a login/password. I set up my username in the install but it did not ask me for a password. Is there a default for this? Unable to load up any kind of start screen, so maybe something went wrong with the script?
which install method did you use? Did you install using firmware.img/partition.img using the official Debian unstable installer?
I used the Daniel Thompson Git Hub link
https://github.com/daniel-thompson/pineb...-installer
I saw a YouTube vid on it and it looked pretty straightforward. I’m guessing that’s not the normal way to do it?
Well, the official way is the one described in the README:
https://d-i.debian.org/daily-images/arm6...ble_images
Success with this method varies, though. I haven't tried it for a while, but I assume once bullseye gets released it should definitely work. Smile
Personally, I recommend doing the installation as described in my blog (it uses stable OS + current mainline kernel, but you can do the same approach to install unstable if you want):
https://www.kulesz.me/post/150_devuan_pinebookpro/
If you installed using Daniel Thompson's installer there is a separate thread for this method here:
https://forum.pine64.org/showthread.php?tid=8487
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 18,776 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 8,545 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 122,821 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 12,402 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 20,299 03-16-2024, 03:09 PM
Last Post: michel_luc
  install debian on pbp jsch 7 12,317 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 23,323 09-07-2023, 09:38 PM
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 4,217 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 3,262 12-19-2022, 01:01 PM
Last Post: Besouro
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 4,881 12-09-2022, 12:43 PM
Last Post: as365n4
