Have inherited frozen braveheart
Have "inherited" a Braveheart from a roomie. They said they could never get UBTouch to work well, so they replaced it with Mobian.
They eventually gave up on it, so now I'm trying to make a go of it.
The Problem: now it only boots to the splash screen and completely locks up.  The battery has to come out to turn it off.
It also won't boot from any SD card, I've tried about 5 or 6 with Jumpdrive or an OS on them - nothing.
So can someone tell me if there's a way to send this phone into a factory reset when starting it up?
(12-14-2020, 03:13 PM)doodah Wrote: Have "inherited" a Braveheart from a roomie. They said they could never get UBTouch to work well, so they replaced it with Mobian.
There is a reset button inside the back cover next to the modem - I have never had to use it so cannot be sure when you should push/release nor quite what to expect.
From your description I fear the mainboard is most of the way to meeting its maker: if you can't get any SDcard image to boot then the SDcard reader is presumably dead and who knows what other issues there are. But doubt the reset button will clear them.
How exactly have you been writing the image to the SD cards? Some people have reported the SD cards are unbootable when written with one tool, only to find the same cards work when written a different way. I think it was Etcher on Windows (and possibly others?) that caused problems but I might be mistaken.
  Ubuntu Touch vs. Manjaro on Braveheart [Accessibility] jazzhands 0 2,680 09-22-2021, 11:52 AM
Last Post: jazzhands
Sad PnePhone Braveheart Edition - Microphone NOT Working valentin 15 20,177 08-09-2021, 07:43 PM
  Soldering novice - Braveheart dead? ConorIA 10 18,614 02-25-2021, 02:38 PM
Last Post: nas
  any user experience with upgrading from the Braveheart? Nooblife 11 18,374 11-10-2020, 03:06 PM
Last Post: bcnaz
  BraveHeart UbPorts Battery drain/Solder update Vlodka 2 7,182 10-04-2020, 11:18 PM
Last Post: Vlodka
Bug Braveheart motor buzzes with pinch Charims 7 14,334 10-04-2020, 11:12 AM
Last Post: roncella
Question Addressing persistent battery discharge on Braveheart User 18618 0 2,970 08-30-2020, 06:00 PM
Last Post: User 18618
  Differences between Braveheart Edition and UPorts Edition Pinephone? kop316 14 26,285 05-07-2020, 01:19 AM
Last Post: MamlinAV
  [BraveHeart] Modem not working sanine 4 9,007 02-18-2020, 04:41 PM
Last Post: wibble
  No IMEI for Braveheart Pinephone? curtvaughan 4 12,211 02-15-2020, 09:23 AM
Last Post: curtvaughan
