Arch Linux ARM on PinePhone
Hi.
I just installed ALARM on my PinePhone with this image and I wondered if full-disk encryption is supported.
If not, how can I build this image with encryption and what would it take to make it use osk-sdl ?
Thanks.
(12-07-2020, 06:40 PM)antoyo Wrote: Hi.
Thanks.
osk-sdl is currently WIP, I'm currently working on it.
Find me in the forest, when I'm at my lowest. I don't really think you should continue..
HOLD YOUR BREATH.
NOTE :
It appears the cellular modem wakes up MUCH faster from sleep state  if the wifi is turned off...
(Seems to me ? )
(06-30-2020, 08:08 PM)Danct12 Wrote: ...
What's not working (or not properly working)
  • You tell me.
20201204 f2fs version, up to date with pacman -Syu. Pretty sure this problem predates December though.
There is a sound "glitch" that stops playback when using lollypop: somehow mpv recovers. The irritating thing is it is not possible to listen to a long track using lollypop. The "glitch" happens at random positions in the same track - it seems more related to what the phone is doing rather than the demands of the track.
With lollypop:
$ lollypop night-raiders-22_10_2020-final.mp3
file:///home/alarm/Downloads/night-raiders-22_10_2020-final.mp3
[INFO] 2020-12-10 10:42:04 Scan started
[INFO] 2020-12-10 10:42:04 lollypop.collection_scanner::__get_objects_for_uris: execution time 0:0.008460
[INFO] 2020-12-10 10:42:04 lollypop.collection_scanner::__scan: execution time 0:0.382076
[INFO] 2020-12-10 10:42:05 Scan started
[INFO] 2020-12-10 10:42:05 lollypop.collection_scanner::__get_objects_for_uris: execution time 0:0.001318
[INFO] 2020-12-10 10:42:05 lollypop.collection_scanner::__scan: execution time 0:0.004950
[INFO] 2020-12-10 10:43:48 Player::_on_bus_error(): ../gst-plugins-good/ext/pulse/pulsesink.c(1750): gst_pulseringbuffer_commit (): /GstPlayBin:player/GstPlaySink:playsink/GstBin:abin/GstBin:bin0/GstAutoAudioSink:autoaudiosink0/GstPulseSink:autoaudiosink0-actual-sink-pulse
This is the journal covering the above fail - I pressed the power key to get the screen active and:
Dec 10 10:43:43 dukla systemd-logind[3255]: Power key pressed.
Dec 10 10:43:43 dukla phoc[6091]: [backend/drm/drm.c:971] Skipping pageflip on output 'DSI-1'
Dec 10 10:43:43 dukla gnome-session[6107]: gnome-session-binary[6107]: WARNING: Could not get session path for session. Check that logind i>
Dec 10 10:43:43 dukla gnome-session-binary[6107]: WARNING: Could not get session path for session. Check that logind is properly installed >
Dec 10 10:43:48 dukla bluetoothd[3408]: Endpoint unregistered: sender=:1.812 path=/MediaEndpoint/A2DPSink/sbc
Dec 10 10:43:48 dukla bluetoothd[3408]: Endpoint unregistered: sender=:1.812 path=/MediaEndpoint/A2DPSource/sbc
Dec 10 10:43:48 dukla systemd[3398]: pulseaudio.service: Main process exited, code=killed, status=9/KILL
Dec 10 10:43:48 dukla systemd[3398]: pulseaudio.service: Failed with result 'signal'.
Dec 10 10:43:48 dukla systemd[3398]: pulseaudio.service: Scheduled restart job, restart counter is at 42.
Dec 10 10:43:48 dukla systemd[3398]: Stopped Sound Service.
With mpv:
$ mpv night-raiders-22_10_2020-final.mp3
[ffmpeg/demuxer] mp3: Estimating duration from bitrate, this may be inaccurate
(+) Audio --aid=1 (mp3 2ch 44100Hz)
File tags:
Artist: Bruce Crompton
Album: Amazing War Stories with Bruce Crompton
Date: 2020
Genre: Podcast
Title: The Night Raiders of Normandy
AO: [pulse] 44100Hz stereo 2ch float
A: 00:00:14 / 00:36:48 (1%)
[ao/pulse] pa_stream_cork() failed: Connection terminated
[ao/pulse] pa_stream_flush() failed: Connection terminated
Audio device underrun detected.
[ao/pulse] pa_stream_get_latency() failed: Connection terminated
A: 00:00:16 / 00:36:48 (1%)
A: 00:00:28 / 00:36:48 (1%)
mpv hiccups at each of the "glitches" but recovers/continues OK.
I can try dig out extra info if required but it sems to me pretty easy to replicate.
I'm on the 20201204 image, and while I don't have any issues, LF had reported good success after updating to 2020/12/05. So, I've tried 'sudo pacman -Syu 2020/12/05', and after saying a few package are up to date, it errors with 'database not found: 2020'. Apologies if it's a stupid question, as I'm not a Linux expert by any means, and have never even used Arch before, but it's the one that works best for me so far.
Thanks,
Edit: I think I realised now that you can't 'sudo pacman -Syu' to a particular date, and LF was just saying that he'd done it on that date. So it's all or nothing, right?
Actually you can roll forward and back if you configure pacman to use the cache. I believe (check this) the default is to store the files from the last update. So , if I am correct, run the standard all or nothing update, if you have problems you can revert to the original state before you started. I have done this more than once on my QA card.  Tongue
See https://wiki.archlinux.org/index.php/Dow...g_Packages
HTH
LF
(12-13-2020, 10:27 AM)Lousy Fisherman Wrote: Actually you can roll forward and back if you configure pacman to use the cache. I believe (check this) the default is to store the files from the last update. So , if I am correct, run the standard all or nothing update, if you have problems you can revert to the original state before you started. I have done this more than once on my QA card.  Tongue
HTH
LF
I cant get megapixels to work anymore. Is it just me (completely up to date pacman -Syu) or has the device numbering changed with a recent kernel update?
alarm@dukla:~$ dmesg | grep video
[    0.102580] videodev: Linux video capture interface: v2.00
[    0.725833] cedrus 1c0e000.video-codec: Device registered as /dev/video0
alarm@dukla:~$ megapixels
Found config file at /usr/share/megapixels/config/pine64,pinephone-1.2.ini
Adding camera rear from config
Adding camera front from config
Found postprocessor script at /usr/share/megapixels/postprocess.sh
Could not open /dev/video1
(12-13-2020, 02:57 PM)dukla2000 Wrote: I cant get megapixels to work anymore. Is it just me (completely up to date pacman -Syu) or has the device numbering changed with a recent kernel update?
That's weird, camera still works with 5.9.14-2
Can you please reboot and dump dmesg to paste.ubuntu.com?
HOLD YOUR BREATH.
Done - I put a month expiry on it to try be a good citizen so anyone reading this thread after Jan 2021 it is to be expected it is no longer there!
I also had a thought overnight that there should be something about the cameras in the log - at 9.5s I can see links but for sure more is missing. In parallel I will try another release via the SDcard - it may be I borked the camera connections when installing the 1.2b board.
p.s. a boot of Mobian from the SDcard gets at least the rear camera working fine in Megapixels.
  PinePhone AND/OR PinePhone Pro Arch Complete Install and Setup mikehenson 3 9,022 01-09-2025, 05:02 AM
  LibreOffice usable with Arch Linux on the Pinephone? Peter Gamma 2 3,349 07-28-2024, 05:12 AM
Last Post: Peter Gamma
  Pinephone with KDE Plasma stuck at K logo after update Daniello 0 1,839 06-20-2024, 01:52 AM
Last Post: Daniello
  Pinephone error system-generators/ostree-system-generator failed with exit status 127 Daniello 3 3,409 06-15-2024, 03:38 AM
  Updating Arch Linux _radv_ 8 8,173 02-20-2024, 09:35 AM
Last Post: _radv_
  How to install arch with FDE user641 3 5,034 01-11-2024, 10:18 PM
  How to find software app, on Arch Phosh? general_lee 5 7,925 10-15-2023, 10:12 PM
  Arch auto mount usb example Lazy_one 2 8,379 10-06-2023, 09:36 AM
Last Post: luppivega
  Arch with FDE user641 1 3,402 07-29-2023, 08:27 AM
Last Post: alpineduck
  No keyboard on Arch Plasma when entering password on document Chief 0 3,005 12-03-2022, 08:35 PM
Last Post: Chief
