PINEBOOK Pro USB-C Docking Deck compatibility
Hello people, just saw on twitter the new PINEBOOK Pro USB-C Docking Deck.
I have 2 question though:
  1. Does this USB-C dock work with any USB-C/Thunderbolt 3 port say MSi notebook?
  2. In my consideration the cable is too short. Some notebooks have the USB-C on the back of the computer so you need at least half a meter to put the dock properly on the side, otherwise you have to buy an extension.
The Pinebook Pro uses USB3 and DisplayPort to communicate with docks. So any other computer (or smartphone) using that should work.
Thus:
Quote:Does this USB-C dock work with any USB-C
Yes.
Quote:Thunderbolt 3 port
Nope. (Thunderbold is about also exposing a PCIe interface, multiplexec together with DP packets. This dock doesn't support PCIe).
Unless the laptop falls back to USB3 + DisplayPort.
But most Thunderbolt laptops should be able, right? (The USB3+DP dock I am currently using (similar to the offical PinePhone dock) advertises compatibility with Mac Air, and my SO's Mac Air seems to recognize it. So I presume other laptop would be able to fall back to non Thunderbolt ?)
At this moment, does it work with Manjaro ARM on Pinebook Pro? And if it does, does it work with the mainline kernel or with linux-pinebookpro package?
(12-03-2020, 07:15 AM)wrzomar Wrote: At this moment, does it work with Manjaro ARM on Pinebook Pro? And if it does, does it work with the mainline kernel or with linux-pinebookpro package?
With latest kernel it does support: https://gitlab.manjaro.org/manjaro-arm/p...core/linux.
I tested the dock against PBP:
- GBE/Audio/USB3/-C does work
- HDMI does work 1080p/60, but I continue to work on 4k/30
- I did not yet test PD
I tested the dock against MBP 2019:
- HDMI does work as expected in 4k/30
- I was able to have get PD (using only the first USB-C) to work with MBP. However, I was not able to see USB-C devices connected upstream to PD port
- I was not able to get DP-ALT to work (likely it is not supported)
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
(12-08-2020, 12:40 PM)ayufan Wrote: - HDMI does work 1080p/60, but I continue to work on 4k/30
How does HDMI work on the dock, does it use a USB3 DisplayLink device? Or does is use the DP alt mode and then a DP to HDMI converter?
(12-08-2020, 12:40 PM)ayufan Wrote: With latest kernel it does support: https://gitlab.manjaro.org/manjaro-arm/p...core/linux.
By the latest kernel, do you mean the one in the ARM Stable Update from today? Does HDMI works with Audio or just Video like on 5.7.19 kernel?
I too would like confirmation on whether it is using DisplayLink or not. I have had a lot of Linux system stability issues with DisplayLink before.
Does the dock work with Windows 10 Intel/AMD CPU?
What about Apple Silicon computers?
(12-24-2020, 06:37 PM)zxorg Wrote: Does the dock work with Windows 10 Intel/AMD CPU?
At least out of box, the dock does not appear to have drives to function in Windows 10.  If someone could point me towards drivers, that would be awesome.
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 2,192 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 2,986 07-23-2024, 07:14 AM
  Pinebook Pro with RK3588? tantamount 28 25,827 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 3,252 04-17-2023, 05:00 AM
Last Post: lkoini
Lightbulb NUT (Network UPS Tools) compatibility Scary Guy 0 2,140 04-22-2022, 08:12 PM
Last Post: Scary Guy
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 3,513 04-16-2022, 07:17 AM
Last Post: jiyong
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 0 3,103 04-06-2022, 01:30 AM
Last Post: zanewiller
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 6,273 01-21-2022, 02:36 PM
Last Post: sascha
  PINEBOOK Pro USB-C Docking Deck compatibility DevonBirch 1 3,583 08-01-2021, 05:13 PM
  Buy a Pinebook kaizmoto1489 3 6,774 07-14-2021, 10:08 AM
Last Post: poVoq
